Old 09-09-2006, 07:35 PM   #1
blkboxster
Guest
Posts: n/a
Tail light
Well im thinking of buying these tail lights.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=130023790012&ih=003&sspagename=STRK%3AMEWA%3AIT
does any body have these on and could give me a pic?
and hows the instlation? could i do it or not or do i take it to porsche and let them install it and would they install it. thanks
Old 09-10-2006, 04:08 AM   #2
Installation is fairly simple. There are some threads on this topic already.
In short, you need to open the rear tunk, pull back the trim, unscrew the lamps,
unplug them, remove the old ones, and install the new ones in the reverse order...
Hopefully the ones on ebay will fit nicely. Some of the aftermarket lamps dont fit that great which may leave bigger than expected gaps. Just ask the seller if he guarantees the fit of these.
I think you can buy the OEM smoked lamps from Brandywine Porsche direct for under 200.00. Just a thought.
Best of luck!
Joe DiMonte
2001 Boxster S
Triple Black
AUDIOGUY is offline   Reply With Quote
Old 09-10-2006, 05:08 AM   #3
blkboxster
Guest
Posts: n/a
Or should i go on the safe side and get these oem
http://cgi.ebay.com/ebaymotors/Porsche-Factory-Boxster-Clear-Tail-Light-Kit-1997-04_W0QQcmdZViewItemQQcategoryZ33716QQihZ001QQitemZ 110030830237QQrdZ1QQsspagenameZWDVW
and not have to worry if they fit correctly.
Old 09-10-2006, 06:46 AM   #4
I bought the non-smoked lenses you are considering and they took about 5 minutes to install. Extremely easy and perfect fit.
joshuaalbert is offline   Reply With Quote
Old 09-10-2006, 06:54 AM   #5
blkboxster
Guest
Posts: n/a
do you mind taking a picture and showing me?
thanks
Old 09-10-2006, 01:55 PM   #6
blkboxster
Guest
Posts: n/a
Well i just bought these on ebay and cant wait for them to come.
http://cgi.ebay.com/ebaymotors/Pors...sspagenameZWDVW
i hope they look good on.
Old 09-10-2006, 03:40 PM   #7
I still live in the stone ages and don't have a digital camera, but I, too, have a '99 and can promise you will have no trouble putting these in.
Old 09-10-2006, 04:07 PM   #8
blkboxster
Guest
Posts: n/a
hahhha its ok THANKS
