Old 09-20-2018, 06:00 AM   #1
IMS shaft: replace single row with double
I am in the process of rebuilding a 2002 2.7 (which has a single row ims) and wondered why the single row ims shaft couldn't be replaced with a double row shaft. Is there any reason that wouldn't work? The double has reportedly been much more reliable but I'm worried about differences in timing chain line or the dimensions or number of teeth on the sprockets.****
dlud is offline   Reply With Quote
Old 09-20-2018, 06:28 AM   #2
BYprodriver's Avatar
I have a double row IMS to do that with but you also need a different crankshaft since the chain drive teeth are different.
Old 09-20-2018, 07:12 AM   #3
thom4782's Avatar
Why bother? The LN Single Row Pro IMS Retrofit kit offers a dual row answer in a single row package.
'87 951
'01S 986 (Sold after 16 years ownership)
'78 924 (carburated; sold when moving to CA)
Old 09-20-2018, 07:31 AM   #4
As mentioned, you would need to take the engine apart and make some significant changes. And if you are looking for reliability, put an IMS Solution in the engine.
Old 09-20-2018, 08:32 AM   #5
thom4782's Avatar
+1...By far, it's the most reliable way to go.
'87 951
Old 09-20-2018, 10:16 AM   #6
Thanks all.
