Old 02-05-2019, 10:33 AM   #1
Plastic part interior soft top
While opening the top, a plastic part broke, any idea on how to fix it?
It's on the passenger side.
Thank you in advance!
P.S. I hope you can see the images
Kostas986 is offline   Reply With Quote
Old 02-05-2019, 11:51 AM   #2
Boo
Boo's Avatar
FYI, I cannot see any images
No images seen on my end.
Boo is offline   Reply With Quote
Old 02-05-2019, 12:01 PM   #3
Now, i think it works.
Old 02-06-2019, 05:18 AM   #4
Anyone? It makes a rattling noise when above 100 km/h
Old 02-06-2019, 06:08 AM   #5
Thom
Cheap fix
So I had the same issue last year when I had my top replaced.
I took a small amount of epoxy and put it on the non-visible side, then used a small paper clamp to hold it closed. Now the epoxy bled over and that clamp is now a permanent part of my car which is fine, it doesn't show or effect any change in fit.
Calmg0d is offline   Reply With Quote
Old 02-07-2019, 01:20 AM   #6
Thank you, but I知 kinda scared to try it. I値l ask if the guys at the shop I知 taking the car for body work stuff can fix it, do you think they might be able? Or will I have to go to Porsche?
Old 02-07-2019, 04:35 AM   #7
Thom
It really is a simple fix. And if you get the really small clips you can never tell it is there because it is hidden by the top and the headliner. However my upholstery guy who installed the top said the epoxy and clamp way is what he would do, but he wouldn't have gotten the clamp stuck in the glue! Anyway, good luck.
Cheers!
Thom
Old 02-11-2019, 10:31 AM   #8
Cheers!
Thom
The guy won稚 fix it, I知 too scared to fix it. So I guess I知 gonna have to take it to Porsche 😔😔.
