Originally Posted by Calmg0d
So I had the same issue last year when I had my top replaced.
I took a small amount of epoxy and put it on the non-visible side, then used a small paper clamp to hold it closed. Now the epoxy bled over and that clamp is now a permanent part of my car which is fine, it doesn't show or effect any change in fit.
Thank you, but I’m kinda scared to try it. I’ll ask if the guys at the shop I’m taking the car for body work stuff can fix it, do you think they might be able? Or will I have to go to Porsche?
