Old 08-14-2018, 07:36 AM   #1
1998 Boxster Silver/Red
Battery Charge/Voltage LED
I'm unable to find the thread wherein it is described how to monitor your battery charge/voltage with an LED digital readout squirreled into the fusebox panel faceplate (?).
If someone could point me to that thread greatly it would be appreciated. Thank you.
1998 Porsche Boxster
Old 08-14-2018, 08:46 AM   #2
Lew
So Blessed!
Lew's Avatar
Could this be what you are looking for....the links not showing up on Ebay.
Very Cool Mod...Volt Gauge
Lew is offline   Reply With Quote
Old 08-14-2018, 10:46 AM   #3
Thank you. However, that isn't it. I recall a picture posted that showed the LED digital readout... maybe 1" x 2". You would cut out the size on the fuse panel door (if you will)... insert it... hook up the wires... voila.
I'll keep looking.
Thanks, again! Cheers!
Old 08-14-2018, 11:48 AM   #4
Something like this would be easy to install:
https://m.ebay.com/itm/Battery-Status-Charge-Indicator-Monitor-Meter-Gauge-LED-Digital-12V-24V/182327475110?
Or this:
https://m.ebay.com/itm/12V-Car-Motorcycle-Digital-LED-Display-Voltmeter-Voltage-Volt-Gauge-Panel-Meter/332518924484?
Old 08-14-2018, 12:35 PM   #5
That'll work. Thank you.
To what would the 2 wires be connected?
Thank you, Sir.
Old 08-14-2018, 12:43 PM   #6
The black wire to any good ground (there should be a ground bolt right by the fuse panel) and the red wire to any switched fuse using a fuse tap (switched fuse would make it so that it only came on with ignition on).
I'll look at the fuses and find a good one later tonight.
Old 08-14-2018, 02:32 PM   #8
I think the link you may have seen was on Pedro's garage years ago. It is under the 'garage' page.
http://www.pedrosgarage.com/Site/Garage_files/VoltageFootwell.jpg
Old 08-14-2018, 04:30 PM   #9
Correct! Thank you. I find this forum to be the finest resource, and thought it was upon these pages I saw that. Thank you.
Old 08-14-2018, 04:32 PM   #10
41, 41, 40, 39, 38, 37, 36, 35, 34, 33, 32, 31, 30, 29, 28, 27, 26, 25, 24, 23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1,
Thank you, Sir.
Old 08-15-2018, 09:45 PM   #11
Yep. I don’t have this exact one, but mine plugs into the cig charger and does its thing. Super easy. Mine also has temp and two USB chargers. Works perfectly, and requires no mods. Just be sure to remove it when done as the cig lighter is constant hot.
Old 08-17-2018, 08:16 AM   #12
There's a hole in the left lower dash for a second cig. lighter. I put one of these in that hole, didn't even take much enlarging of the hole. It's wired in to the power feed for the radio. Works great. https://www.amazon.com/gp/product/B06XHJ3WTL/ref=s9_acsd_zgift_hd_bw_b1402d_c_x_w?pf_rd_m=ATVPD KIKX0DER&pf_rd_s=merchandised-search-8&pf_rd_r=ZJGKA69AFR086475EXDY&pf_rd_t=101&pf_rd_p=47595890-73ad-5d76-bb3a-a9a9c076405f&pf_rd_i=15729811&th=1
2001 Boxster
2007 Toyota Highlander
Old 08-17-2018, 08:23 AM   #13
Lew
So Blessed!
Lew's Avatar
Originally Posted by Brian in Tucson View Post
There's a hold in the left lower dash for a second cig. lighter. I put one of these in that hole, didn't even take much enlarging of the hole. It's wired in to the power feed for the radio. Works great. https://www.amazon.com/gp/product/B06XHJ3WTL/ref=s9_acsd_zgift_hd_bw_b1402d_c_x_w?pf_rd_m=ATVPD KIKX0DER&pf_rd_s=merchandised-search-8&pf_rd_r=ZJGKA69AFR086475EXDY&pf_rd_t=101&pf_rd_p=47595890-73ad-5d76-bb3a-a9a9c076405f&pf_rd_i=15729811&th=1
A picture would be nice! I don't see this hole you are talking about.
