Old 08-14-2018, 04:32 PM   #10
Starter986
1998 Boxster Silver/Red
The black wire to any good ground (there should be a ground bolt right by the fuse panel) and the red wire to any switched fuse using a fuse tap (switched fuse would make it so that it only came on with ignition on).
I'll look at the fuses and find a good one later tonight.
41, 41, 40, 39, 38, 37, 36, 35, 34, 33, 32, 31, 30, 29, 28, 27, 26, 25, 24, 23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1,
Thank you, Sir.
1998 Porsche Boxster
