Old 08-09-2018, 09:15 AM   #1
Rubber air feeds to transmission
Not sure what they are called. There are two rubber pieces that attach to the suspension brace (aluminum triangle) that the two diaganol supports in the rear suspension attach to. I believe they help air flow up the tranny. I bought the rubber pieces and a plastic plug for each that just popped right into the hole in the rubber. Does anyone know if there is another connector piece that goes through the top? The plugs were small plastic hollow tubes (open on one end) with one side having a push end. The old one was one there for the 3 years and I never had any plugs to hold on so likely won't be an issue but I figure since I already went this far, I might as well do it right.
Thanks,
David
Old 08-09-2018, 11:33 AM   #2
This guy??https://www.pelicanparts.com/More_Info/98633136103.htm?pn=986-331-361-03-M100
If so there are male & female plastic T connectors that snap together to hold it in place, so it sounds like you are missing the male pieces.
98 Arena Red 986
Old 08-10-2018, 09:37 AM   #3
Mine are missing, are the T connectors available from pelican?
Luckyman01 is offline   Reply With Quote
Old 08-10-2018, 10:18 AM   #4
Answering my on question
Also use (Qty.) (1) 999 507 774 40 retainer, (1) 999 507 775 40 retainer, for each air guide.
