Old 08-09-2018, 09:15 AM   #1
DWBOX2000
Rubber air feeds to transmission
Not sure what they are called. There are two rubber pieces that attach to the suspension brace (aluminum triangle) that the two diaganol supports in the rear suspension attach to. I believe they help air flow up the tranny. I bought the rubber pieces and a plastic plug for each that just popped right into the hole in the rubber. Does anyone know if there is another connector piece that goes through the top? The plugs were small plastic hollow tubes (open on one end) with one side having a push end. The old one was one there for the 3 years and I never had any plugs to hold on so likely won't be an issue but I figure since I already went this far, I might as well do it right.
Thanks,
David
DWBOX2000 is online now   Reply With Quote
