Old 07-20-2018, 01:31 PM   #1
Foam drip tray replacement
How difficult is it to replace foam drip trays?
Charliemarlie is offline   Reply With Quote
Old 07-20-2018, 02:04 PM   #2
seningen's Avatar
I can't remember the details -- but I think you do have to remove the convertible top transmissions, but overall, not that hard.
If you are replacing the top -- you have to be real careful with the "arms", they are just dying to poke a hole into your drip trays -- that's how I did mine in.
However, I think you can do one tray at a time without completely removing the top.
M
mike@lonestarrpm.com
Old 07-20-2018, 05:34 PM   #3
The local dealer quoted me 1200 to replace the trays. They said the top has to be removed and the trays were 130 each.
xzyfsk is offline   Reply With Quote
Old 07-20-2018, 07:54 PM   #4
If you're inclined to consider replacing the trays yourself, understand that removing the top may sound daunting but in fact, will take you less than an hour. There are lots of good instructions online but overall, you are looking at putting your top in the service position, disconnecting the arms and undoing three bolts and one or two screws from each side. The whole top will lift out of place.
Old 07-20-2018, 10:40 PM   #5
seningen's Avatar
I would check with Sunset or Suncoast first -- It's been ~8 years -- but I remember them being ~$20.
Just looked up Sonnen they want $140 each -- wow -- I don't remember them being that pricey.
Mike
Old 07-21-2018, 08:47 AM   #6
That's insane! Any competent porsche mechanic can replace both in an hour
Woody
Old 07-20-2018, 05:49 PM   #7
How bad is your tray? Can't you fix it with waterproofing tape and done with it?
