Old 07-17-2018, 04:28 AM   #1
Rain water leak
Hi all
Have recently bought boxster s
Year 2000 model
Has very bad rain water leak behind both seats,
All drain holes are clear,water seems to be entering near seat belt area,in rear corner of interior,roof in good order,please any advice apprecicated
Charliemarlie is offline   Reply With Quote
Old 07-17-2018, 06:32 AM   #2
Did you test the drains to see that water going in to the drains comes out under the car? The tubes might be disconnected. How are the door windows sealing against the top frame? That's all I've got.
Old 07-17-2018, 12:01 PM   #3
I think i have found the problem both foam drain trays are damaged ! Not sure whether I can repair them or may have to replace them.
Thanks for your input
Old 07-17-2018, 12:25 PM   #4
I thought the tubes coming out of the drain hole in the foam trays were optional. As in not present from the factory for certain years. I've never looked under the foam tray - can anyone confirm whether the draining water must enter the tube in order to properly drain to the outside? Thanks
Old 07-17-2018, 04:48 PM   #5
1997 Tip, 2018 Macan
rexcramer's Avatar
If you haven't yet, do it right now. Get your front seat out, raise your controls up out of the water and start drying everything out. Expensive bad things are in your future if you don't. Good luck.
