Old 07-07-2018, 04:27 AM   #1
flouese's Avatar
Engine install
Is s there a DIY substitute for a flywheel locking tool?
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 07-07-2018, 04:31 AM   #2
Little piece of metal with 2 holes for a bellhousing bolt and pressure plate bolt or dowel
Old 07-07-2018, 07:45 AM   #3
Flouese,
I used before a strip of angled iron with holes (the kind used for shelves, etc) and connect one of the flywheel bolts to one of the bellhousing holes.
First attach the FW side (loose) and then you move the strip of metal around until one of the holes align with one of the holes on the bellhousing, then tighten both ends will allow to torque down the flywheel.
This is what has worked for me, good luck!
Old 07-07-2018, 11:27 AM   #4
I used heavy duty zip ties.
CdnRD is offline   Reply With Quote
Old 07-07-2018, 07:15 PM   #5
https://www.homedepot.com/p/Basset-Products-3-4-in-x-50-ft-Perforated-Galvanized-Steel-Duct-Strap-DS50-1-28G/205871091?cm_mmc=Shopping%7cTHD%7cG%7c0%7cG-BASE-PLA-AllProducts%7c&gclid=Cj0KCQjwyYHaBRDvARIsAHkAXcuRvWB3-dWLDCloc8Oij2-KH3jo3gs6k9pz6GORRQ9h1OVXiNVnQCsaAtrBEALw_wcB&gclsrc=aw.ds&dclid=CNqkqt_EjtwCFWIIZQodts8I8Q
Joe K. Peachtree City GA
2001 986 Boxster S, Silver with black interior.
blueflames is offline   Reply With Quote
