Old 07-03-2018, 06:05 PM   #1
2003 S, Arctic Silver, M6
paulofto's Avatar
There are drain holes in the front and back.
Back..... raise the top to the service position and look on either side where the roof retracts and you will see a drain hole at the bottom of a foam catch basin. Make sure they are clear of leaves and debris. Check for any tears in the foam as well.
Front...... Open the frunk and at the cowl area there are two covers one each side. These are removed with a torx driver. You will need to remove the battery cover as well I believe. Again, ensure the drain holes are clear.
A little preemptive work can go a long way to preventing a catastrophe.
Old 07-03-2018, 06:23 PM   #2
Look at these picture and diagrams
Old 07-03-2018, 07:34 PM   #3
Originally Posted by mikefocke View Post
Thank you, I have read your site but missed that page. Thank you again
gsy4771 is offline   Reply With Quote
