Old 06-25-2018, 08:48 PM   #1
Whistle from pipe attached to intake manifold. What part is this?
Does anyone know what this port is for and why it's whistling on my 2000 Boxster S?
I found in the PET that the port that attaches to the manifold there is part 996 110 151 00. But I can't find what the hose is that it attaches to. The whistle seems to be in the pipe/hose it attaches to, not this adapter/port itself.
Jay Laifman is offline   Reply With Quote
Old 06-25-2018, 09:06 PM   #2
Brake booster vacuum line.
It's leaking.
Old 06-26-2018, 05:44 AM   #3
Are you replacing your engine? Probably the dismanteler just cut the tube. There's a fitting on the other plenum, too. Opposite end. On manual engines it's on one end, on tiptronics it's on the other. The one that 's not used has a block off plate.
2001 Boxster
2007 Toyota Highlander
Old 06-26-2018, 06:50 AM   #4
Thanks! No, this is not my engine and it hasn't been removed. I just grabbed this picture to show it. I will see about replacing the line or whatever seals there are at its joints. Thanks.
