Are you replacing your engine? Probably the dismanteler just cut the tube. There's a fitting on the other plenum, too. Opposite end. On manual engines it's on one end, on tiptronics it's on the other. The one that 's not used has a block off plate.
2001 Boxster
2007 Toyota Highlander
