Old 06-14-2018, 06:46 AM   #1
"50 Years of 550 Spyder"
10/10ths's Avatar
Since we don’t have superconducting, helium cooled, maglev bearings, we are left with the same old roller or ball bearings with moving bits that can fail, or diamond like coated, high pressure synthetic oil floated, plain bearings. Seems simple to me.
EVERYTHING can fail. No kidding.
It was an exaggeration to make a point.
What kind of bearing is in all of your crank journals and piston big and small ends?
What kind of IMS bearing is in a Metzger engine?
Physics is physics. How anybody can look at all of the designs available and not choose the Solution is beyond me.
Alright, I will shut up about it and quit posting and go back to actually driving the snot outta my Boxster and see if I can grenade the damn thing and give you a failure data point to share.
Freaking paralysis by analysis.
Just install the “Solution” and get busy driving. We all only get so many sunsets.
Old 06-14-2018, 10:28 AM   #2
Holy crap
Old 06-14-2018, 02:34 PM   #3
MWS
....We all only get so many sunsets.
For some reason this made me smile...
Old 06-14-2018, 04:37 PM   #4
10/10ths's Avatar
Ok....
...I stand by my statement.
The "IMS Solution" will NOT grenade.
There. I said it.
How many of the plain bearings on the OTHER end of the IMS shafts have failed?
I had to stop to refuel, so I figured I reply.
Old 06-14-2018, 04:40 PM   #5
There. I said it.
I think Jake spent a long time and a
Lot of research in Determining the exact metals to use in the solution. If you have held it in your hands It
Definitely gives you a very good feeling that it will not fail.
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
Old 06-14-2018, 05:01 PM   #6
There. I said it.
The plain bearings on the other end of the shaft are not on the bulk of the load.
Like I said, it looks promising. But, since I'll never change my original dual row bearing anyway, it really doesn't apply to me.
My point was that an opinion is just an opinion.
Looking at it from an engineering standpoint, they will fail. It's just a matter of when and whether or not they will outlast the engine/car.
The added friction could also cause wear on the shaft which isn't built (hardened) for that type of bearing/friction.
Old 06-14-2018, 05:07 PM   #7
Motorist & Coffee Drinker
78F350's Avatar
And so goes another fine technical discussion of the IMS.
Cats anyone?
Old 06-14-2018, 05:13 PM   #8
10/10ths's Avatar
Particle wave....
...I'm just kidding about it NEVER failing. Of course, any part can fail. My point is that the a forced lubricated, plain bearing, with a diamond like coated surface, is the most reliable type of bearing for that application.
And over the last 100 years or so of internal combustion engines, that seems pretty well proven out in the real world.
There's no tone in text, so I probably came across a bit strident.
Old 06-14-2018, 12:34 PM   #9
Rickvd's Avatar
Not the full article but an interesting portion in reference to Mark Jennings Article
Good Vibrations
Rickvd is offline   Reply With Quote
Old 06-14-2018, 12:45 PM   #10
Rickvd's Avatar
Here is the full article
http://inwr.pca.org/LinkClick.aspx?fileticket=KksL3MCtE9s%3d&tabid=40
Starts on page 15.
Here is where it gets interesting...
Page 19 - The Boxsters;
We had 3 Boxsters, two with fairly
high mileage and one with low
mileage. All 3 of these cars are 5
chain engines. The low mileage
car had a suspected timing chain or
IMS bearing issue
. The vibration
data from the 2 higher mileage cars
looked very similar, high amplitude
combustion peaks where predicted,
fairly high amplitude Cam Chain
noise, very low Primary Chain noise
with no discernible sidebands. The
higher Cam Chain noise from these
engines is most likely normal; chain
stretch and chain guide wear, etc…
The low mileage Boxster with the
suspect timing chain or IMS bearing
issue had both a high amplitude Cam
Chain gear-mesh frequency and an
EXTREMELY high Primary Chain
gear-mesh frequency. Definitely a
chain or bearing issue; no doubts,
shut her down, get her fixed.
Conclusion page 20
Since our January 7th Saturday tech
session, the IMS bearing has been
pulled from the Boxster with the
suspected issue and sent to me. Sure
enough, a deformed bearing cage
allowing the bearing balls to fall out
of position
. Just enough additional
clearance was introduced to the
intermediate shaft that an increase
in backlash between the chain and
sprockets generated substantially
higher vibration amplitudes (makes
a lot of noise). We caught this guy
before any huge amount of metal
could be sucked into the oil and
damaged other components.
Now to contact Mark and find out where this is currently at... Stay Tuned - Rick
Old 06-14-2018, 01:33 PM   #11
There have been so many false starts at problem detection and isolation. Mark was to come to a meeting of Boxster owners held in the NC mountains back in '12. He was going to use the meeting to gather data so he had many more samples. I had linked him up with the sponsors of the BRBS and stepped back from the arrangements. For some reason, it didn't happen. I didn't hear from him again.
Old 06-14-2018, 06:28 PM   #12
No worries...I definitely come across thick-headed.
Like I said, I don't have a dog in this fight, anyway.
I honestly haven't researched the solution, other than brief descriptions and pictures. Is it just solid aluminum, or does it have some other surface material?
Old 06-14-2018, 08:16 PM   #13
10/10ths's Avatar
It has what is known as a “Diamond Like Coating”, often referred to as “DLC” in engineering circles. I’m on the road, so I’m not in a position to post a link, but if you go to the Flat 6 web site, there is a detailed description.
Old 12-23-2018, 01:48 PM   #14
I must be alone, I am not changing my ims bearing,I am driving it like I stole it. If something happens then I will deal with it then. These cars are not worth anything regardless so why spend 3000 or more to fix something that hasn’t failed. Either way you won’t get your money back. There are a lot of other things that can grenade your engine. Keep the oil changed and just drive the heck out of it. There is a guy on this forum who had 300000 miles on his car and he never heard of ims bearing.go figure,just my opinion
Jimbo409 is offline   Reply With Quote
Old 12-23-2018, 02:53 PM   #15
1997 Tip, 2018 Macan
rexcramer's Avatar
+1 You are not alone. I have zero problems with being pro-active with maintenance issues. Where you stop, is an individual choice/gamble.
I am most bothered with the idea that you need to spend that +/- $3 grand every four years or 50k miles. But first you are required to pre qualify your motor and prove that it is sound, prior to spending the money?
Old 12-23-2018, 03:56 PM   #16
Who's askin'?
maytag's Avatar
Nope.... not alone.
I did mine because I had clutch failure. I wish I hadn't done it. The bearing in there had 147k miles on it, and looked perfect. I'd have been better off leaving it.
I just put the cheap pelican kit in it.
Old 12-23-2018, 08:52 PM   #17
Why spend 3-8 k on a car that is worth 10. The failer rate is estimated at 8%. Maybe more with age but who knows. I figured mine is dispensable. If she goes she goes. It's still worth what 3-4 to someone as a roller. If I felt I enjoyed it enough I can get another one. Just make sure you have towing on your insurance. I
MrBen is offline   Reply With Quote
Old 12-23-2018, 10:30 PM   #18
Nope, haven’t done mine either... I will when it’s clutch time... I suppose if my motor explodes before then, well I guess it does, and if that is the case then it was on its way out anyway and would not have qualified. BTW, no metal in my oil as of yet. 02 S 60ish K.
