Old 05-27-2018, 11:23 PM   #1
Will there be cake?
tonythetiger's Avatar
Spacers...
Team,
What are the widest spacers I can put on a stock 986 S without rubbing. I was thinking 20mm front, 15 rear, but I want to use stock bolts for the wheel and thought I'd ask who sells a complete kit. Advice on width and sourcing would be appreciated.
I have the 18" wheels.
Old 05-28-2018, 12:01 AM   #2
Pirate50's Avatar
All spacers will require longer lug bolts according to Porsche
2004 986 Basalt Black Metallic. L&N IMS Retrofit, 996 Door Cards, Smarttop, Aerokit II bumper and sideskirts, Toth ducktail
Pirate50 is offline   Reply With Quote
Old 05-28-2018, 02:06 AM   #3
WALDMEISTER
BRAN's Avatar
That is right, except for their own 5mm spacers. And according to Porsche, it is not recommended to run different sizes (front/rear). But that would mean 5mm front/rear only. TÜV did not complain, when approving my set up, so...
Old 05-28-2018, 06:02 AM   #4
edc
550 Anniversary
edc's Avatar
Even the OE 5mm spacers come with longer bolts.
Old 05-28-2018, 06:47 AM   #5
1998 Boxster Silver/Red
Originally Posted by tonythetiger View Post
Team,
I'm not a rocket surgeon... but wouldn't the size of your wheel reveal if there's going to be rubbing or not? I'm running the stock 16s with 20mm spacers rear... 10mm front.
What size wheel you running? Did I miss something?
I went with ECS. Came with the extended bolts.
1998 Porsche Boxster
Old 05-28-2018, 11:04 AM   #6
A8ked's Avatar
I'm using 20mm spacers front and rear with the original 17" turbo twist wheels. I purchased the spacers thru ECS, they came with the correct length longer bolts.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
Old 05-28-2018, 11:54 AM   #7
Could you possibly post some pics of the 17+spacers? I'm interested in this route myself.
Lapister is offline   Reply With Quote
Old 05-28-2018, 03:57 PM   #8
Will there be cake?
I have the original 18" twist wheels, stock tire size and want the wider stance. Not sure if 20mm spacers in the rear will introduce rubbing or not, hence the question.
It seems that 15mm are the most popular, which gets me thinking that wider might present an issue
Old 05-28-2018, 03:59 PM   #9
edc
550 Anniversary
edc's Avatar
If you are that concerned get a couple of rulers and see for yourself. Measure the gap from the wheel to the outer arch liner
Old 05-28-2018, 06:27 PM   #10
I run H&R 23mm spacers in the rear with both my stock 17” twists & my Carrera lights.
5mm up front, IIRC.
98 Arena Red 986
Old 05-28-2018, 08:52 PM   #11
Lew
So Blessed!
Lew's Avatar
Can you post a picture of the car?
Lew is offline   Reply With Quote
Old 05-29-2018, 05:35 AM   #12
That you've finally revealed your wheel size now causes everything to make sense. Thank you.
Old 05-29-2018, 05:36 AM   #13
5mm up front, IIRC.
I'm wishing I had purchased the 23s for the rear. 20 just seems a little shy.
Old 05-29-2018, 07:08 AM   #14
Cunningr's Avatar
5mm up front, IIRC.
Can you post a pic? I have the 17" twist on my 00, looking at the spacers too, was thinking 15mm all around.
Old 05-29-2018, 02:17 PM   #15
If interested I have a set of 15MM with Bolts for sale. Posted in Parts for sale.
Van
Old 05-29-2018, 06:30 PM   #16
pidj's Avatar
So, I wouldn't just be able to add 20mm spacers on the rear (to a stock 'S' setup)?
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
Old 05-30-2018, 12:27 AM   #17
Racer Boy
Racer Boy's Avatar
You need the longer bolts, too.
Old 05-30-2018, 01:36 AM   #18
Cunningr's Avatar
Van
Can you link to the other post as I couldn't find it? Was looking at ECS but no 15MM with bolt sets in silver only HR which seem too expensive. like $350
Old 05-30-2018, 02:43 AM   #19
edc
550 Anniversary
edc's Avatar
You can do that if you want to.
Old 05-30-2018, 03:41 AM   #20
Cunningr,
Here is the For Sale post.
FS 15mm spacers
Van
