Old 05-23-2018, 01:39 PM   #1
Will there be cake?
tonythetiger's Avatar
2002 Boxster s convertible top question
My 3rd boxster is a 2002 boxster s with the glass back top.
need a sanity check, cuz when I try to put the top in service mode and access the engine bay, I cannot articulate the top out of the way...(ive done this 100 times on my other cars and it just works) this one,I cannot figure out why the top doesn't move out of the way...it looks fine closed, opens fine...everything looks normal.
I'm starting to think something is bent or is there a different trick for the glass back?
UPDATE:
Let me add to this post rather then start a new one...The aftermarket top isn't closing properly, picture below. What to do for fix?
Old 05-23-2018, 02:42 PM   #2
still plays with cars...
BoxsterSteve's Avatar
Does the car have a replacement glass windowed roof on its original 3-bow frame?
They’re a PITA to work around.
Six speed 2000 Boxster S
Old 05-23-2018, 03:53 PM   #3
Will there be cake?
IDK if it is original or replacement. I thought the 2002 came with a glassback. It is the original frame, pretty sure, but the top already looks aged, so I am surprised if the top isnt original also.
Old 05-23-2018, 05:12 PM   #4
"50 Years of 550 Spyder"
10/10ths's Avatar
You have an aftermarket top.
OEM glass window appeared in 2003.
Old 05-24-2018, 07:50 AM   #5
Will there be cake?
alright, thanks. Is it common that an aftermarket top is difficult to work around...not get out of the way in service mode?
any tricks out there?
I am only getting about 5 inches of movement and cannot get to the engine.
Old 05-24-2018, 09:37 AM   #6
1998 Boxster Silver/Red
That's the best you're going to get, and plenty of posts about it here. I've read that with the glass window simply remove a few fasteners from the clamshell and the top... and fold everything back straight. That should fix the accessibility challenge.
Before you start removing clips... pins... fasteners... make sure you remove them properly. I learned the hard way, and when I went to reinstall... had a few fasteners that had lost their efficacy. That was a visit to the dealer for $5 worth of fasteners... including spares.
Remove the fasteners... and report back!
1998 Porsche Boxster
Old 05-24-2018, 10:09 AM   #7
Will there be cake?
thanks, I will and hopefully help someone else.
Appreciate the feedback
Old 05-24-2018, 10:05 PM   #8
Interesting, as I own an 02 with vinyl, fortunately still in great shape. So what causes this issue? Is the window, being glass, simply getting in the way? Seems it makes more sense to go big and swap the system for an 03+ when the time comes?
Old 05-25-2018, 04:37 AM   #9
Multi-Boxer Driver
Deserion's Avatar
Basically, yes. Since the 3-bow frame is meant for the plastic window, the glass makes it more difficult to fold up.
If you're able to, I highly recommend it. You'd end up with a larger glass window on top of being able to fold it up easily. Plus the glass has the Porsche script on it so you can stare at it in the rearview, heh.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
