View Poll Results: What's Your Position on Fuel?
I'll seek out non-ethanol fuel at any cost 4 13.79%
I'll use non-ethanol if/when I come across it 10 34.48%
I don't fret over the type of fuel I use 15 51.72%
Voters: 29. You may not vote on this poll
Old 05-15-2018, 08:12 AM   #1
Non-Ethanol Fuel
Curious how everyone is about fuel....
1998 Porsche Boxster - Ocean Jade Metallic
1985 Porsche Carrera Targa - Guards Red
1978 Porsche 911SC Euro Non-Sunroof - Grand Prix White
Seadweller is online now   Reply With Quote
Old 05-15-2018, 08:30 AM   #2
98 Arctic silver 986
tommy583's Avatar
I use it from time to time, but I always use it when I store the car for the winter.
Old 05-15-2018, 03:56 PM   #3
there's no "real gas" available locally, so I can't worry about it. When I lived in the Pac. NW, there were a couple of places in the small town that carried it. I tried it in my V8 pickup, it didn't make it run any better and I couldn't see any better gas mileage.
Our gas in Tucson all comes from the same terminal. Only difference is the additive package. So I use one of the more budget gases, Fry's/Kroger, and I buy Techron by the quart or half gallon when I can find it.
2001 Boxster
2007 Toyota Highlander
Old 05-15-2018, 04:01 PM   #4
Oldcarguy's Avatar
Originally Posted by Brian in Tucson View Post
. . .Our gas in Tucson all comes from the same terminal. Only difference is the additive package. . .
After 30+ years in O&G exploration and production I can assure you that this is the case more often than not.
Rgds, Fred
Old 05-15-2018, 06:20 PM   #5
Some very small airports and of course marinas have the gas you're looking for.. will they sell you some is the question.
mikeinmass is offline   Reply With Quote
Old 05-15-2018, 07:10 PM   #6
SC-986's Avatar
Plenty of "Pure" gas stations here in the southeast. It is the only thing I will put in our vehicles unless there are no other options. We have a '95 Jeep Wrangler that recently had to have all the rubber fuel lines replaced because the 10% ethanol fuel destroyed them. I use the "Pure Gas" app when traveling outside our local area to identify stations that offer 100% gas.
2002 Boxster base - Seal Grey, 5spd trans.,ROW M030 upgrade, FVD Brombacher software tune
2004 550 Spyder Anniversary Edition, #1541,Tip, TechnoFix DOF IMSB upgrade
SC-986 is offline   Reply With Quote
Old 05-16-2018, 04:58 AM   #7
Multi-Boxer Driver
Deserion's Avatar
Locally I can only get ethanol-free in 89. So regular E10 in 93 it has been.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 05-16-2018, 09:02 AM   #8
Wawa and a couple of other stations in my area have non-ethanol, though I'm not sure of the octane. I'm pretty sure however it's 89. I am definitely concerned with the effect of ethanol fuel on the rubber lines.
Old 05-16-2018, 11:25 AM   #9
I believe that the Ethanol (and Methanol) affects the metal fuel lines as it promotes rust, but may be wrong..
Old 05-16-2018, 11:50 AM   #10
Old 05-16-2018, 11:53 AM   #11
Gas containing ethanol has multiple downsides:
1. A given volume of ethanol is approximately one third lower in BTU output than the same volume of pure gas, so any level of ethanol is going to have lower power potential.
2. Ethanol picks up water and carries it in gas. As the direct result, any gas containing ethanol will cause mild steel fuel system components, lines, or tanks to rust.
3. Vehicles converted to E85 use have all stainless fuel components and special injectors to deal with the corrosive nature of higher alcohol level's water content.
Old 05-16-2018, 01:41 PM   #12
Curious on your thoughts of running non-ethanol 89 octane vs. E10 93 octane ? As you stated any % of ethanol will have less BTU's then " straight " gas . So is non 89 close to E10 93 octane ? Will there be a noticeable difference in performance ? I know the knock sensors will kick in if needed but just curious on your thoughts . My gut tells me 89 octane non-ethanol may be the better choice .
Old 05-16-2018, 01:43 PM   #13
MWS
It's too darn bad we can't just stop subsidizing ethanol...if we did, the price would be prohibitive and demand would drive the reversion to "regular" gasoline. I understand this is a complex issue with multiple parties involved, but if there are tax dollars used to artificially hold down the cost of the fuel, I'd greatly prefer the same dollars just be given to the growers and producers directly...perhaps as an incentive NOT to produce.
I guess I look at it this way...if ethanol was such a great fuel, by demand there would be far more vehicles that use pure ethanol than there are now. In a free market, consumers (by the wisdom of the masses) choose the best product. In a subsidized market, those forces are stunted and the natural evolution and progression of products are forcefully directed, quite usually toward a less favorable outcome.
Cork in mouth...rant over. Sry.
Old 05-16-2018, 01:52 PM   #14
A best, the performance differences for four octane rating numbers is small, but still in the favor of the 93. If you are concerned about the corrosion potential from the ethanol, simply add something like StaBil when filling up, which will prevent the problem while stabilizing the fuel.
Old 05-16-2018, 01:59 PM   #15
Buy the highest octane, either 91 or 93, that you can find from the busiest, nation brand gas station. Don't fret about 10% ethanol. Octane trumps ethanol.
Old 05-16-2018, 02:25 PM   #16
Thank you for the reply .
Old 05-18-2018, 06:18 AM   #17
This is a great forum. I have been in the gas business for many years and this is the first thread regarding ethanol blended fuels that did not include combat between posters. It is also very refreshing to see accurate and factual responses regarding this highly charged and often political issue.
JohnRedS is offline   Reply With Quote
Old 05-18-2018, 06:23 AM   #18
Hahah. Just don't ask "what oil should I use?".
Old 05-19-2018, 06:58 PM   #19
Unsure what the cocktail is in the US but in Canada Shell v-power has 0% ethanol. That’s all I used in my 986 and now my 987. I have no scientific reasoning, but anecdotally, I used to have an RX-7 and it seemed to have some issues running on ethanol content, I switched over and everything smoothed out.
Jim Rockford is offline   Reply With Quote
