Old 05-16-2018, 12:41 PM   #12
rfuerst911sc
Gas containing ethanol has multiple downsides:
1. A given volume of ethanol is approximately one third lower in BTU output than the same volume of pure gas, so any level of ethanol is going to have lower power potential.
2. Ethanol picks up water and carries it in gas. As the direct result, any gas containing ethanol will cause mild steel fuel system components, lines, or tanks to rust.
3. Vehicles converted to E85 use have all stainless fuel components and special injectors to deal with the corrosive nature of higher alcohol level's water content.
Curious on your thoughts of running non-ethanol 89 octane vs. E10 93 octane ? As you stated any % of ethanol will have less BTU's then " straight " gas . So is non 89 close to E10 93 octane ? Will there be a noticeable difference in performance ? I know the knock sensors will kick in if needed but just curious on your thoughts . My gut tells me 89 octane non-ethanol may be the better choice .
rfuerst911sc is offline   Reply With Quote
