Old 05-07-2018, 07:44 PM   #1
ISSIMI
Clunk feel in steering wheel when going over bumps
Hey guys.
I need some help diagnosing a suspension issue. There is a "clunk feel" through the steering wheel when going over bumps. It is more apparent at low speeds. No noise was heard during this clunk.
Other than the clunk the steering seems fine. The car turns and handles normal.
Describing the feel i get from the steering wheel over a bump is like a quick jolt to the steering wheel.
Most_Wanted is offline   Reply With Quote
Old 05-07-2018, 08:06 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
Get both front wheels off the ground and then pull on the wheels. Have somebody gently steer while you hold. Loose or damaged connections might present themselves. 2nd, pull the wheels off and start looking at all of the connections. Good luck.
Old 05-08-2018, 07:39 AM   #3
How many miles are on the car?
speedyspaghetti is offline   Reply With Quote
Old 05-08-2018, 09:06 PM   #4
Racer Boy
Racer Boy's Avatar
Most likely culprits are tie rod ends, or lower control arms.
Old 05-09-2018, 01:03 PM   #5
I would also suggest the front track arms - they are relatively cheap (you can use the 911 part) and I was able to get some vibration out of my steering with replacing them. It's not 100% gone, so I'm going to do LCAs later this week. I did tie rods too, but they didn't really change the "clunk" for me.
Old 05-11-2018, 10:51 PM   #6
ISSIMI
103200 miles. I have been reading up on similar issues related to mine being correlated to the tie rod bushings tho. Thanks for the tip on lifting the front and checking for wheel looseness.
spaghetti thanks for the tip. I'm not getting any vibration from the steering wheel though. Just a jolt /clunk over bumps. More noticeable at slow speeds.
Old 05-12-2018, 12:47 AM   #7
Cunningr's Avatar
No vibrations maybe its a worn front shock strut.
Old 05-12-2018, 10:50 AM   #8
Racer Boy
Racer Boy's Avatar
With over 100K, chances are good that everything is worn out. If you are going to take it apart to replace one part, you may as well replace everything while you are at it. Yes, it's expensive, but save yourself the trouble and just get it all over with! Your reward will be a car that is quiet and drives great.
Old 05-15-2018, 12:54 AM   #9
Oggie's Avatar
I've just gone through this process trying to track down a similar noise, replacing part after part and in my case it was the sway bar drop links
'99 base Boxster (Arena Red Metallic/Savanna Beige)
'02 911 Carerra Cabriolet (Arctic Silver/Metropole Blue)
Oggie is offline   Reply With Quote
