Old 04-18-2018, 02:56 PM   #1
Help please! Transaxle serial number location?
I have an ‘03 non-S Boxster (986.2) and cannot find the serial number on the transaxle. I have found a code on the bottom that is EFD 1311.
Appreciate the help
2003986 is offline   Reply With Quote
Old 04-18-2018, 03:47 PM   #2
911monty's Avatar
That is your serial number/code. The code is located bottom right edge of the trans just aft of the axle flange. It can also be on the top of the bell housing. First 3 letters for the 00 and later 5 speed is EFD.
Old 04-18-2018, 04:09 PM   #3
Porsche "Purist"
Paul's Avatar
13 1 1 most likely is January 13, 2001, the date the tranny was built.
1987 924S. 2002 996TT. PST-2
Old 04-18-2018, 04:41 PM   #4
So is the serial number the build date number I see on the bottom of the trans?
Old 04-19-2018, 07:02 AM   #5
No, I don't believe so..
The invoice on my 987 gearbox repair it shows the S/N G872110020519 therefore, your tranny must have the S/N somewhere but I am not sure where, however I have seen it before..
Old 04-19-2018, 08:58 AM   #6
911monty's Avatar
Pretty sure that is a combination of your transmission model number shown on the under hood option sticker, G87.2/100... and the trans code 0519.
The PO's would be G86.1/...1131. The workshop manual shows the code as the only identifier on the trans. The date code/location may change on the later models as my manual is for the 04 and earlier 5 speed.
Old 04-19-2018, 04:04 PM   #7
Why do you want to know the code? Basically the transmissions are the same 00-02. I believe the 03/04 5 speeds use larger bolts for the axles and that the only difference
Woody
Old 04-20-2018, 07:05 AM   #8
It’s on the top of the gearbox. The numbers underneath don’t have anything to do with the serial number
amondc is offline   Reply With Quote
Old 04-20-2018, 12:57 PM   #9
Thanks, found this to be true.
