Old 04-14-2018, 07:15 PM   #1
My Camshaft Deviation Numbers
Camshaft Deviation #1: -7.02
Camshaft Deviation #2: -8.36
Read from a Durametric with the car at proper temperature (driven for 20 min+ prior). Car is a 2000S, running fine with no codes. Based on what I have read from searching the variocam pads need replaced. My question is can I expect to see the deviation come down within spec of +/-6 with just the pad change or could there be other things at play here?
JavPit is offline   Reply With Quote
Old 04-14-2018, 07:34 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
How many miles on the motor? And do you know if the IMSB is the original?
Old 04-14-2018, 08:29 PM   #3
76k on the motor. IMSB was changed by the previous owner at around 70k.
Old 04-14-2018, 08:46 PM   #4
Damn Yankee
TeamOxford's Avatar
Originally Posted by JavPit View Post
...... or could there be other things at play here?
Sure thing, such as chain tensioners. I wouldn't redline the engine until you get this sorted out.
Just sayin'............
TO
Old 04-15-2018, 06:23 AM   #5
thom4782's Avatar
Worn variocam chain rails
Old 04-16-2018, 07:36 AM   #6
Replace both the variocam wear pads and the 4th and 5th timing chains. I had a 2000S with cam deviations of 7.xx and 5.xx. The wear pads were extremely worn on both banks. The cam deviations are now in the 2's.
dlud is offline   Reply With Quote
Old 04-16-2018, 09:39 AM   #7
Artist, 986S tinkerer
NewArt's Avatar
+1
Pad change: parts don't cost much, but it's labour intensive. You can DIY if you are brave. I did mine when one was at 8 or nine. You need the cam lock tools ( I made mine).
