Old 04-11-2018, 08:19 AM   #1
P2096
i have a fault code on mijn 986 s 2003
P2096 Post Catalytic Fuel Trim Bank 1 System Too Lean
i replaced the post cat o2 sensor, but the fault comes back after 80 miles
when i read the o2 sensors value with started engine
bank 1 post cat sensor stays almost all the time at 0.1 v
on bank 2 the sensor is 0.1 at idle, on acceration it goes up to 0.6-0.8
but bank 1 remains at 0.1
when i go off trottle both the sensors go to 0.000
both the o2 sensors are new,
the dealer thinks i have a bad cat, but he is not 100% sure
take the gamble en replace?
or are there things i can check myself?
tjokke is offline   Reply With Quote
Old 04-11-2018, 09:03 AM   #2
now by accident, i noticed that in high rpm above 5000,
the sensor react normal,
Old 04-11-2018, 12:17 PM   #3
Are the front O2s cycling back and forth on both banks?
bwdz is offline   Reply With Quote
Old 04-11-2018, 01:03 PM   #4
Yes they act normal going from 0.1-0.8
The second sensors
On bank 2 stays 0.1 on idle
En Goes slowly up When i raise rmp or driving
On bank 1 iT stays 0.1 if i drive
Only at high rpm iT Goes also to 0.6-0.8
