Old 03-26-2018, 08:17 AM   #1
gabedrummin's Avatar
Lowered 986 supenssion
How low can a Boxster be safely lowered? I bought a set a Yellow Racing Coil overs Last April just now getting around to installing them and it seems like the car will be too low.
gabedrummin is offline   Reply With Quote
Old 03-26-2018, 10:30 AM   #2
Not sure about the suspension but nice height stand and granite table
bockster75 is offline   Reply With Quote
Old 03-26-2018, 11:18 AM   #3
Thank you sir .Think I will make new lower brackets for the coil overs so the drop wont be so much.
Old 03-26-2018, 11:46 AM   #4
Rennzenn
j.fro's Avatar
Rule of thumb is not to let the control arms go below horizontal. Here are a couple of side shots that show where my car ended up.
Rennzenn
Jfro@rennzenn.com
Old 03-26-2018, 12:18 PM   #5
They actually don't look that much shorter if you look where each of them will bottom out in the knuckle.
Old 03-26-2018, 01:15 PM   #6
Just about 1.200 of drop. That lowered 986 looks nice do you recall how much it is lowered?
Old 03-27-2018, 10:41 AM   #7
Rennzenn
j.fro's Avatar
It's like 1.5-2". Corner balancing moved it about some, too.
Rennzenn
Jfro@rennzenn.com
Old 03-29-2018, 05:53 PM   #8
-Pete
I guess my brother ruined me, because the first thing I saw was a drum stick!
I just installed a set of Vogtland lowering springs on my friends '01 986 S and it dropped it about an inch. I would have preferred about 1.5-2" myself for appearance sake, but it really depends on what you do with the car and how much you want to put into being able to adjust camber and toe and all the things that start becoming issues with lowering.
NVYELLO is offline   Reply With Quote
Old 03-30-2018, 04:22 PM   #9
Comment removed.
Old 04-01-2018, 04:31 AM   #10
Going thru the same thing...
H&R Street Sport Coil Over Ride Height LOW
I’d like a solution that added back 1” or so. Might have to be springs. My setup retains the stock upper front and rear mounts so spring choices might be limited. I’ll swap those if I have to but would prefer to keep the rubber (mostly street car).
'01 986S
‘07 GT3
'80 911SC Weissach Edition (Sold)
‘11 958 S
https://dergarage.com
CBRacerX is offline   Reply With Quote
