Old 03-14-2018, 08:32 AM   #21
When the lip on either side of the rotor is 1mm it is due for replacement. I have a set of calipers that I measure the rotor thickness with. A lot easier than measuring the lip.
1941 Dodge Luxury Liner Coupe
Old 03-14-2018, 10:18 AM   #22
I am running a set of Sebro slotted rotors in the front from them. They are still going strong, but I was wondering the same thing, when do they consider them to be done so I can send them back and get the next free set
I've sent parts back that outwardly looked fine.
Something as simple as claiming they are warped is likely good enough.
I'm not sure they care, strange as it is.
Old 03-20-2018, 07:07 PM   #23
I just replaced the pads on all four wheels (along with rotors) about 4 months ago and used Akebono pads. Very happy with them, no noise, very little dust and stop great.
Stephan is offline   Reply With Quote
Old 03-24-2018, 09:48 PM   #24
Two things I never scrimp on, tires and brakes. Very happy w Zimmerman rotors and EBC yellow pads.
opus69 is offline   Reply With Quote
Old 03-26-2018, 08:29 AM   #25
Bosch pads
Last fall (50k miles) I replaced (original?) Brembo pads w/ Bosch. They do not make contact w/rotor to the outer edge which leaves about 1/8" of surface rust showing on Rotors...They stop just fine but suck astetically..Would buy the Brembos if I could do over...
STRANGEPOLLY is offline   Reply With Quote
Old 03-26-2018, 08:31 PM   #26
MarkAP's Avatar
Do you have the part number and which line it is? My department and I would like to investigate this.
Mark
Guards Red Boxster S, born in Germany May 2004. LN spin on filter, litronics, roll bar mesh, wind deflector. Pioneer AVH-4200 hu, rear shelf box with speakers installed. 36k miles.
MarkAP is offline   Reply With Quote
