Old 03-08-2018, 05:39 PM   #1
1998 Boxster Silver/Red
Is this correct?
98 Boxster
I'll be installing the S coil cooler this Spring. Among the associated parts I've been hoarding I have the o-rings for the oil cooler.
These rings look rather large and, not having pulled the original oil cooler, would like someone to chime in and tell me the rings look to be the correct size and that, once I pull the original cooler, it will be clear.
Or not.
Which one?
Thank you.
1998 Porsche Boxster
Old 03-08-2018, 07:20 PM   #2
Artist, 986S tinkerer
NewArt's Avatar
Hard to tell from the photo but yes, the rings are seated in the engine block and not in the cooler, so they will be larger than the in/out ports on the cooler. Use the o-ring numbers that petain to your motor.
Old 03-08-2018, 07:51 PM   #3
98 Boxster
Or not.
Which one?
Thank you.
No. Two of the rings are a different size and usually also a different color (green).
Old 03-08-2018, 08:07 PM   #4
NewArt's Avatar
Different sizes, yes. Different colours, not necessarily. There are two different models of cooler, one with a chamfered connection (green o-ring) and one without (black o-ring). See the PET and the corresponding notes for clarification.
Old 03-09-2018, 05:16 AM   #5
Thank you, all. Will order the 2 smaller rings.
I've 2 extra o-rings if anyone needs them. Gratis. PM me.
