Old 07-16-2016, 06:13 PM   #1
front trunk hood.
My front trunk won't open as far as it used to.
How is this adjusted?
Fuzzuki is offline   Reply With Quote
Old 07-16-2016, 08:13 PM   #2
still plays with cars...
BoxsterSteve's Avatar
If you mean it won't lift as high... the small lift cylinders are probably pooched.
Six speed 2000 Boxster S
Old 07-16-2016, 08:40 PM   #3
Damn Yankee
TeamOxford's Avatar
The spring on the release mechanism is weakening; getting ready to fail. Replacement of the entire unit is necessary. It's an easy fix, and not that expensive.
You can get a used unit from Woody, or any other recycler, or you could just buy a new one.
Just sayin'...........
TO
p.s. Better get one soon before you can't access the frunk at all.
Old 07-17-2016, 10:24 AM   #4
Where is the spring?
TO
Old 07-18-2016, 04:08 AM   #5
Luckyed
Luckyed's Avatar
It's a piston. They are cheap. Don't buy used ones.
2001 Porsche Boxster Base Convertible - Bumpers, Doors, Latches & Lids - Page 7
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 01-13-2018, 10:57 AM   #6
Reading back. I guess my original question was a bit unclear.
When you pull the frunk release lever, it was not popping up enough to get a finger beneath it.
I found out today that the rubber stopper can be adjusted.
Dah.
Old 01-31-2018, 05:52 PM   #7
I had the same problem. I fixed it by hosing down the latch mechanism with spray silicone lubricant.
Also, be careful that you don't adjust the stoppers too far out which can elevate the leading edge of the hood above the front bumper when the hood is closed. It's designed to be just below the bumper.
jdavis8361 is offline   Reply With Quote
