Old 01-16-2018, 03:41 AM   #1
Oldcarguy's Avatar
Ack - oiled air filter
Just discovered that sometime in my 986’s past a P.O. had installed a BMC oiled air filter
At least it doesn’t appear to have been over oiled. Don’t have any fault codes so I’m just going to install a new Mahl before I button it back up. Why people do this is beyond me.
Rgds, Fred
Old 01-16-2018, 04:52 AM   #2
Multi-Boxer Driver
Deserion's Avatar
I'd clean the MAF while you're in there, just to make sure it's cleaaaan.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 01-16-2018, 04:58 AM   #3
still plays with cars...
BoxsterSteve's Avatar
I did that on my 2000... cleaned the MAF even though it was behaving and not coding. Figured at 14 years old, it might be necessary.
Fargin’ bastidge failed almost immediately afterward.
If it’s not misbehaving, you might consider leaving well enough alone.
Six speed 2000 Boxster S
Old 01-16-2018, 05:24 AM   #4
Oldcarguy's Avatar
I’ll check the intake tract when I change the filter. If it’s not oily / dirty, I’ll leave the MAF alone.
Rgds, Fred
Old 01-16-2018, 05:25 AM   #5
kk2002s's Avatar
PO had installed a K&N air filter. I had one on my mustang GT so I was familiar with them. I never had any issues with either. Ran the Oiled filter in the Box for a couple of years. I did switch to regular dry filter. I was going on 2000+ mile road trip, wanted clean air filter and did not want to add another variable to the drive event. I have stayed with the dry filter since
Seal Grey
Old 01-16-2018, 05:52 AM   #6
Its not the end of the world. BMC is a quality filter.
Old 01-16-2018, 06:02 AM   #7
Oldcarguy's Avatar
True, they’re well known in the motorcycle world. I’m not anticipating any problem with the MAF because the filter appears to have been oiled properly (not over oiled). I’m just not a fan of these in fuel injected vehicles running in dusty environments.
Rgds, Fred
Old 01-16-2018, 10:26 PM   #8
I’ve had two MAF’s fail after cleaning (not Pcar) so I just leave them alone now. If there are MAF related issues I would rather just replace it.
Old 01-17-2018, 07:11 AM   #9
Ciao's Avatar
When I purchased my Box 2 years ago, I went through and checked the air filter and discovered it was a K&N clogged with debris. I changed it to a OEM filter after a year, I cleaned the K&N re-oiled it and use it. The sound from the intake is much more pleasurable with the K&N. I never checked the MAF as I have not codes.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 01-18-2018, 12:22 PM   #10
jb92563's Avatar
Yes, don't touch the MAF if its behaving, you WILL regret it if you do.
Old 01-18-2018, 02:15 PM   #11
Oldcarguy's Avatar
Agreed, leaving the MAF alone until it codes.
Rgds, Fred
