Old 01-01-2018, 11:31 PM   #1
Naught window micro switch or door lock
Hi Chaps
After the big UK freeze my drivers side window has now decided to rise to the fully up position as soon as I let the exterior door handle go! I have to now then get in the car lower the window then close the door. Im worried every time my lovely wife drives the car because its not something she will always remember to do lol. Luckily enough she prefers our VW Passat.
Iv had my mechanic look at it and he says the micro switches look ok so he thinks its the door lock. They are £170(ish) brand new but Im aggrieved to spend that incase its not so I have bought a tested/guaranteed one from a Porsche breakers near me for £30.
Seemingly its a common fault??
Its getting fitted this evening so Ill let you know.
I was whinging to my mechanic about how hard it is to get in the car when its frozen due to the windows freezing to the seals, he recons spraying the seals weekly with a clear silicone spray during winter will stop it happening, has anyone else tried this?
Peter
YellowS2000 is offline   Reply With Quote
Old 01-02-2018, 08:26 AM   #2
Finnegan's Avatar
Hi Peter,
This was me, last week! I had the same symptoms, although they were intermittent. I took it to my indie shop and they said the whole driver's side lock mechanism had to be replaced; they could not just replace the micro switches. All better now, after a few hundred $$. Best of luck!
Old 01-02-2018, 01:49 PM   #3
Re: window freezing. I live where it is cold, snowy and icy 4 or 5 months / year. It is -22c right now outside. And yes, silicone on the rubber will work and help the windows with not sticking on the à seal. I apply it a few times a winter; otherwise keep the seals super clean (and dry).
CDNIcecube is offline   Reply With Quote
Old 01-02-2018, 07:47 PM   #4
Naught window micro switch or door lock.
You're better off simply keeping the seals clean and dry. Silicone will also make the rubber brittle over time. You'd be better off using vaseline or white grease instead. Both
petroleum products that won't harm the rubber seals. Never mind that silicone is toxic.
2001 Boxster S, Metallic Black, 6 Speed Manual, 3.2 liter engine.
RobertKing is offline   Reply With Quote
Old 01-04-2018, 06:40 AM   #5
Thanks Ill give it a go, does it smear on the glass?
