Naught window micro switch or door lock.
Originally Posted by CDNIcecube
Re: window freezing. I live where it is cold, snowy and icy 4 or 5 months / year. It is -22c right now outside. And yes, silicone on the rubber will work and help the windows with not sticking on the à seal. I apply it a few times a winter; otherwise keep the seals super clean (and dry).
You're better off simply keeping the seals clean and dry. Silicone will also make the rubber brittle over time. You'd be better off using vaseline or white grease instead. Both
petroleum products that won't harm the rubber seals. Never mind that silicone is toxic.
2001 Boxster S, Metallic Black, 6 Speed Manual, 3.2 liter engine.
