Old 12-28-2017, 09:23 AM   #1
Boxster Ignition Switch Cross Reference
Morning everyone. Been on the hunt for an ignition switch locally and have some cross reference numbers for those who use the Box as a daily and can't wait on shipping parts.
This ONLY for ignition switch Audi/VW 4b0 905 849 which my car had installed as an 01 S.
Borg Warner CS781 - Napa
Import Direct 18-0551 - Orielly's
Duralast LS966 - Lifetime Warranty from Autozone
Hope this helps someone....Thanks!
Dillier23 is offline   Reply With Quote
Old 12-28-2017, 11:21 AM   #2
Hope you find a good one. I bought the NAPA brand one as I couldn't wait for the Meyle I ordered online, and it only lasted 6 months, the original lasted 13 years. The cheaper ones made in China are made from a harder, more brittle plastic that doesn't hold up nearly as well as the Euro brands.
Old 12-28-2017, 07:03 PM   #3
I thought the 4B0 switch was for 2004 and up and the earlier cars took the 4A0 switch. My '00 S has the 4A0 p/n.
__________________________
'58 356A coupe, just a driver
356Guy is offline   Reply With Quote
Old 12-29-2017, 07:50 AM   #4
kirkandorules's Avatar
I'd highly recommend 986 owners keep a spare in their car. Mine kinda crapped out abruptly, though I'm lucky that the major symptom was that the car wouldn't shut off (ignition was stuck in accessory with the key out) so I was at least able to drive home.
There are some that are Amazon Prime eligible, which might be another quick option for some.
'99 986 Ocean Blue Metallic
'87 924S, winter beater
'17 VW Golf Sportwagen, for when I need extra seats
kirkandorules is offline   Reply With Quote
Old 12-29-2017, 01:51 PM   #5
I ordered mine from Amazon a few days ago and it arrived today. It was $12. I'll keep the old one as an emergency spare.
Old 12-30-2017, 05:49 AM   #6
356Guy,
Can you post the link to the Amazon switch you got for $12? I see a few that would work for my base 1999 but ain’t sure about quality (l am also in Canada). Thanks
CDNIcecube is offline   Reply With Quote
Old 12-30-2017, 07:46 AM   #7
Originally Posted by CDNIcecube View Post
356Guy,
I got the last one at $12. Its now $16
https://www.amazon.ca/URO-Parts-4A0-905-849B/dp/B0066SFYMO
Its cheaper at Pelican if you are already buying something there (shipping kills) I would probably just go to the Audi or Porsche dealer if I was in a hurray.
Old 12-30-2017, 07:49 AM   #8
Good. Ordered that one as an “extra”. The part worked well for you?
Old 12-30-2017, 11:55 AM   #9
Yes works fine.
Old 12-30-2017, 06:27 PM   #10
Autopartsway.ca for ignition switch in Canada
If in Canada get yours from Autopartsway.ca for $15 and my came the next day. I'm not associated with them in any way.
Part Number: MEY1621815
Part Name: Ignition Starter Switch
Porsche-Eh is offline   Reply With Quote
Old 01-05-2018, 06:22 AM   #11
If the part had been updated to the newer style it’s the B designation. You are correct in that the original piece is replaced with the A designated part number.
Old 01-05-2018, 07:24 AM   #12
or here:
https://www.amazon.com/URO-Parts-4A0-905-849B/dp/B0066SFYMO
Meyle:
https://www.amazon.com/Meyle-W0133-1621815-MEY-Ignition-Switch/dp/B001G6K91M/ref=cm_wl_huc_item
BEfore you buy, confirm here if the A or B part will work for your Year.Pelican will tell you.
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dautomotive&field-keywords=4b0+905+849&rh=n%3A15684181%2Ck%3A4b0+905+849
or Meyle:
https://www.pelicanparts.com/More_Info/4B0905849MY.htm?pn=4B0-905-849-MY-INT&KeepHeader=Y&ByPassCat=Y&null=
