Old 11-26-2017, 04:17 AM   #1
Is this the cover on top of the interior door handle?
My passenger side is all scratched up for some reason. I think I found the part but it says it doesn't fit my 04 s?
https://www.getporscheparts.com/oem-parts/porsche-cover-98655559200b12
This being the curved plastic trim covering the interior door pull handle mechanicals. The
pinksnyper is offline   Reply With Quote
Old 11-26-2017, 04:20 AM   #2
I'm talking about the black trim the accepts both the door handle pull and the longer door handle arc below it: http://www.williamscrawford.co.uk/wp-content/uploads/2011/10/986-3.2-0071.jpg
Old 11-26-2017, 05:14 AM   #3
Motorist & Coffee Drinker
78F350's Avatar
That is the basic part, but if you look at the details, the one you selected: 986-555-592-00-B12, is for 1997-1999 and is unpainted, plain plastic.
Yours is the '01 and I expect it's painted black? If so, I see 986.555.592.01 A03
https://www.getporscheparts.com/oem-parts/porsche-cover-98655559201a03
A lot more money for a little black paint.
Old 11-26-2017, 05:27 AM   #4
Thanks! That's interesting, when I look at it , it certainly just looks like black plastic trim but I guess it could be painted? It's very matte.
Old 11-26-2017, 06:27 AM   #5
Rustoleum makes a black multi-surface filling primer which matches Porsche’s 9x6 interior trim black exceptionally well. Plus it’s much more durable than the factory “soft touch” finish.
Good luck
"Cool Prius!"
- Nobody
Old 11-26-2017, 06:47 AM   #6
Good luck
Ooooo. Link? I googled but found way too many options. Do you have to sand the plastic to prep or?
Old 11-27-2017, 08:34 AM   #7
Out of town at moment and will gladly check what currently is in my inventory when I have time next weekend. That said, have use a couple different rattle cans of Rustoleum primers and all were good match. Either of these should work:
https://www.lowes.com/pd/Rust-Oleum-Stops-Rust-Black-Enamel-Spray-Paint-Actual-Net-Contents-12-oz/3048639
https://www.lowes.com/pd/Rust-Oleum-Universal-Flat-Black-Enamel-Spray-Paint-Actual-Net-Contents-12-oz/3728795
Yes, you need to prep the plastic.
Good luck
"Cool Prius!"
- Nobody
Old 11-27-2017, 05:10 PM   #8
PS - Been quite some time since I removed that piece on a Boxster but...
If memory serves me correctly (HA a rarity at times!) that piece requires some finesse releasing the clips correctly. Nothing catastrophic if not done 100% correct but do search the archives here for door panel removal or door speaker upgrade for details on how to do so appropriately to avoid any errors.
"Cool Prius!"
- Nobody
Old 12-01-2017, 04:46 PM   #9
I'll be damned. I ordered Rust-Oleum interior trim spray in satin and it looked awfully shiney. Then I got one you recommended (I ordered the first before your post), and it looks amazing! I used 800 wet sandpaper to do some gentle sanding first. I'm going to do my arm rest lids next and call it a day. Thank you for the cost savings recommendation!!
