Old 11-25-2017, 10:28 AM   #1
Remove white wax residue from rear bumper plastic bumper things
Sorry I'm not sure what the two bumps by the rear plate are called. I foolishly got compound residue on them. I've tried, so far, without success:
  • Wd40
    Goof off
    Dawn
What the heck
pinksnyper is offline   Reply With Quote
Old 11-25-2017, 10:43 AM   #2
still plays with cars...
BoxsterSteve's Avatar
Always had good luck with Mother’s Back To Black.
Or just prep them and do them to match the car.
It looks great when the bumperettes are colour matched.
Lots of threads on doing this floating around.
Six speed 2000 Boxster S
Old 11-25-2017, 10:59 AM   #3
husker boxster's Avatar
Pink Pearl pencil eraser.
As Steve says, those are bumperettes.
1989 928 S4 5 spd - black
Old 11-25-2017, 11:29 AM   #4
Thanks gents. Now have gotten really interested in the bumperette removal all together!
Old 11-25-2017, 01:40 PM   #5
1997 Tip, 2018 Macan
rexcramer's Avatar
+1 for the Mother's Back to Black.
Old 11-25-2017, 05:14 PM   #6
You can remove them, it only takes a 6mm Allen key, but you expose the bracket they affix to, and the hole in the bumper cover underneath.
Look in my garage photos, there’s a pic there of my painted bumperettes.
It takes various grades of sandpaper, high fill primer, base coat and catalyzed clear coat and a couple of days to get it all done.
Bumper Plugs sells complete painted ones, but I’m too German to spend that kind of bread.
Old 11-26-2017, 02:43 AM   #7
That looks great. For the novice painter, do you have a guide of sorts?
Old 11-26-2017, 10:19 AM   #8
A8ked's Avatar
I did something similar with wax. I used some full strength Simple Green and a tooth brush, took it right off...
A8ked is offline   Reply With Quote
Old 11-26-2017, 11:01 AM   #9
I don't have any on hand. Surprised my full strength goof off didn't work though
Old 11-26-2017, 11:36 AM   #10
I started with 400 grit to sand off all the pebble finish, then went to 800 grit then 1000.
Then I laid on a coat of high build primer and sanded with 1500 grit. Did it again.
I sprayed light coats of base coat until the can was empty, then did the same with the catalyzed clear.
Old 11-26-2017, 03:32 PM   #11
I had Bumper Plugs do mine and they exchanged a set they had for mine plus my credit card, of course. They were a perfect match and held up perfectly for the 5 years I owned the car. Never read a bad forum comment about them.
Old 11-26-2017, 06:01 PM   #12
If you decide to stick with black bumperettes...
I used Back to Black for a while, and liked it reasonably well. Problem was, it didn't last very long. I switched to Forever Black---lasts MUCH longer.
