Old 11-16-2017, 07:27 AM   #1
IronDeadPool
For those going into Winter Mode.
Good Morning fellow Boxster owners,
This is the first year that my car will go into hibernation, my question to everyone is;
1) how do you prep your car 4 winter.
2) how many times a week do you start your car.
3) do you remove the batter or trickle charge it.
Any advice is greatly appreciated!
P O R S C H E . B O X S T E R
Project IronDeadPool
986ohana is offline   Reply With Quote
Old 11-16-2017, 07:42 AM   #2
1. Fill tank with premium and add Stabil -
2. Tires to 50 psi to avoid flat spotting
3. Park in heated storage
4. Trickle charger / maintainer
5. Cover
6. Wake it up in April. No mid-storage starting.
FoxRvrBox is offline   Reply With Quote
Old 11-16-2017, 08:49 AM   #3
98 Arctic silver 986
tommy583's Avatar
5. Cover
I would add.
Change the oil.
Fill gas tank with non ethanol gas if possible.
If a manual, leave out of gear with e brake off. Chock tires to prevent rolling.
Wash car if possible.
Old 11-16-2017, 09:07 AM   #4
I would add to do something about mice.
Moth balls, traps, glue stick. One eaten wire and you will be wishing you used it as a plow truck. Ok, I am exaggerating but it does really stink.
DWBOX2000 is online now   Reply With Quote
Old 11-16-2017, 09:47 AM   #5
I would add: for mouse I use Bounce sheets all over the interior and trunk + frunk
Also, crack open both windows about 1/2 inches.
pomerlo is offline   Reply With Quote
Old 11-16-2017, 10:33 AM   #6
+1
No eaten wire, but last spring I found a bunch of mouse-chewed stuff in my air box
Old 11-16-2017, 11:48 AM   #7
Maintainer, Noah cover. Parked under the assumption that I'd be able to get it out every few weeks. I did. No starts just to start. If I started it, it was to drive 15-20 miles to work and then back home. Oil changed before winter if not by 5k miles. Did this for 5 years. 5 years, 40 k miles and two owners later it was still fine last I heard.
Old 11-16-2017, 05:48 PM   #8
Ciao's Avatar
I would add: depending on your environment stuff exhaust with material and loosen (release the tension) on your top, condition the leather
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 11-20-2017, 02:05 PM   #9
wash car
Wheel stoppers
disengage ebrake
make sure in neutral
Open drivers door
disconnect battery
leave frunk ajar
close drivers door
cover
That's all I do plus add stabil if I remember
Old 11-21-2017, 03:01 PM   #10
This works! They're nice and tight--I'm sure no rodents could get around--but still easy to get out. I also zip-tied a clean rag around it after taking this pic. This was more to discourage my dog from trying to pull the balls out of the exhaust than anything else...he lives to fetch those things!
Old 11-21-2017, 04:35 PM   #11
Why no E brake?
Fuzzuki is offline   Reply With Quote
Old 11-21-2017, 06:15 PM   #12
Originally Posted by Fuzzuki View Post
Why no E brake?
The e brake shoes could seize against the inside of the e brake drum in the rotor hat. Not sure if it's a form of galvanic corrosion or rust grabbing ahold of the shoe material.
Old 11-21-2017, 07:26 PM   #13
pidj's Avatar
E-brake consideration is always a good idea. The 'out of gear' is not something I consider - over 16 years of storing vehices over the winter and I leave it in gear - never an issue.
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
Old 11-21-2017, 07:47 PM   #14
What is the hibernation spot you have to park it like? Flat or a slope? How secure? Covered? Climate?
Old 11-22-2017, 03:40 AM   #15
Yeah, me too...for 10+ years anyway. Though, in my case, I suppose it's not necessary: the car sits in the garage, a completely level surface. Still, in the spring she slides outta gear just as smoothly as she slide into gear in the early winter.. I DO leave the brake off however.
Old 11-22-2017, 08:59 AM   #16
pidj's Avatar
typical garage, relatively flat a few degrees warmer than outside (ie insulated garage doors) but not heated
Old 11-23-2017, 08:14 AM   #17
Wallace River's Avatar
Thanks for reminding me!
It went up to 15 degrees C here yesterday, 60 degrees F so had final oil change done, washed car in driveway (wearing shorts!) and put it away in the garage, battery tender plugged in to sigarette lighter. BUT forgot the Bounce fabic sheets, I stuffed them in the tailpipes and all the nooks and crannies last winter and no mouse issues, so gotta get that done now.
The name's Ian....now a former owner.....sold my 2000 Speed Yellow Base to its new owner in Nova Scotia.
Wallace River is offline   Reply With Quote
