Old 08-05-2006, 07:22 PM   #1
Thinking of an alignment.
My Boxster's alignment is due for a makeover. I know before I take it in I should have a full tank of gas. What else? Does anyone have that chart from Porsche of the specs for an alignment?
Old 08-05-2006, 09:11 PM   #2
About that time, heh? I just had mine done not too long ago, and it did help, was getting a bit of understeer.....Lot better now!
Heres the specs for a 2000, I think it should be the same for your '99.....courtesy of deliriousga
wheel alignment
A decent shop should have the Boxster specs tho....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 08-06-2006, 07:17 AM   #3
Brucelee's Avatar
Smile
If it is near that time, new tires are now something to consider.
If not, I would rebalance the tires while you have it at the shop. Check for bent rims etc.
Rich Belloff
Old 08-06-2006, 07:00 PM   #4
Should you always get an alingment when getting new tires?
docdyh is offline   Reply With Quote
Old 08-07-2006, 06:09 AM   #5
Yes. Laser, four wheel alignment is my preference. Far better than the older method.
Old 08-07-2006, 06:34 AM   #6
Brucelee's Avatar
Smile
Yes. That will maximize how long your tires last.
Rich Belloff
Old 08-07-2006, 07:19 AM   #7
Firestone lifetime alignment
Hey guys and gals,
For those of you that have gotten the "Lifetime Alignment" from Firestone...
how good is it? Do they use the proper equipment and do it properly on the Boxsters?
:dance:
Visit Porsche Site.com
Iatros is offline   Reply With Quote
Old 08-07-2006, 07:30 AM   #8
I would wait a week or so after getting the new tires before getting an alignment....This gives the car a little time to get used to the different dynamics of your new tires.....
