Old 10-19-2017, 11:17 AM   #1
Vacuum readings
Ok, somehow I managed to loose the instructions on the digital tool to measure the vacuum on my engine and must ask this question...
What is the proper way to use the tool, leaving the second port open:
Or by covering the second port:
Now, assuming that mi engine is below the 5" of H2O, does this means that my rings are too worn, or it could be that I have a small vacuum leak?
Thank you in advance for your comments!
Old 10-19-2017, 01:25 PM   #2
The second port should be left open.
Old 10-19-2017, 01:54 PM   #3
that is a pretty trick digital gauge.
I have a $20 analog gauge.....is it accurate enough?
How much is the high tech one??
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
Old 10-19-2017, 02:54 PM   #4
oldskool73's Avatar
Those ones are resold everywhere, about $35+ from ebay
https://www.ebay.com/itm/2017-LCD-Digital-Manometer-Differential-Air-Pressure-Meter-Gauge-2Psi-13-79Kpa/112313519245
...or a little less all over the chinese sites...
https://www.aliexpress.com/wholesale?catId=15370801&initiative_id=AS_20171019145012&SearchText=digital+manometer
oldskool73 is offline   Reply With Quote
Old 10-19-2017, 03:05 PM   #5
Thank you! Now, I know how to use this gizmo
