Thread: Vacuum readings
Old 10-19-2017, 11:17 AM   #1
Gilles
Vacuum readings
Ok, somehow I managed to loose the instructions on the digital tool to measure the vacuum on my engine and must ask this question...
What is the proper way to use the tool, leaving the second port open:
Or by covering the second port:
Now, assuming that mi engine is below the 5" of H2O, does this means that my rings are too worn, or it could be that I have a small vacuum leak?
Thank you in advance for your comments!
Gilles is offline   Reply With Quote
