Old 10-08-2017, 03:37 PM   #1
Doing the right thing
I bought a really run down 01 Boxster for less than half what you paid. I've learned some things. About buying a cheap or badly mechanicked Porsche.
One, indy Porsche shops don't like them. They see the fubar suspension or blown strut dampeners, or split boots on the CV joints and immediately tell you that it's not worth fixing and I (you) should call the pick n pull and have it towed off. If it were my car, I'd take it to a alignment/suspension specialist--a shop that specializes in these services. Go first cabin on this, it's important! As someone mentioned you may need to get the frame trued up, too.
Two, there are alternatives to brand new genuine Porsche parts. There are good aftermarket alternatives--The online perveyor that starts with Rock and ends with auto, for example, sells Bilstein struts. You might investigate the suspension section for your year/model car. They also have control arms and steering components. I'd probably do all four corners on the suspension (probably will on mine.)
Three, there are parts cars that can serve as donor vehicles--in your case, I'd probably look into used stock loaded struts. Worst case, rebuild or have them rebuilt with new dampeners. Disclaimer: I live in a very dry warm climate--rubber parts degrade, but rust is unknown here.
First things first, tho. Get the poor little car so it's driveable.
2001 Boxster
2007 Toyota Highlander
Old 10-09-2017, 03:48 AM   #2
Project Addicted
jcslocum's Avatar
Is it possible to see a picture of just how low the car is?? This issue shouldn't really make the car unstable and have no grip. A pic from the side would be helpful
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 10-09-2017, 03:48 PM   #3
I judged who I wanted to align my car by how many racing cars of similar make/model/vintage he had in his shop and was setting up for the track. And I was wanting a road only setup that favored tire wear! Why the racing setup guy? Because he knows the effects of the setups, not just stock and out the door and on to the next one.
Frame alignment check after an accident is done with a Porsche supplied jig or a laser driven tool. Mine was done after an accident at a very high end body shop.
Where are you located? Maybe someone can give you a recommendation.
Old 10-10-2017, 04:41 AM   #4
GTA_G20's Avatar
+500 , the alignement shop should be able to tell you what components are worn beyond adjustment
+2 if you test drove this car. I'm surprised you couldn't feel the car wandering all over the road. if the suspension was that bad I'm surprised you bought it
GTA_G20 is offline   Reply With Quote
