Old 07-31-2006, 08:06 AM   #1
Clutch Engagement when hot
I have a 99 Boxster with 64k miles and noticed that after driving for long periods the clutch doesn't engage smoothly when starting from a stop. When first staring off for the day the clutch seems smooth in 1st gear no jerkyness. I'm wondering is this is a sign that the clutch is worn or somthing to do with the manual transmission itself? Again, it's notciable when it's hot. The car is only street driven and not very hard. Any ideas are welcomed - thanks
AllanAA is offline   Reply With Quote
Old 07-31-2006, 08:19 AM   #2
What you are experiencing is typical of a worn clutch not a transmission. Regardless of how hard you drive it - Boxsters go through them pretty damn quick. Sorry - time to replace that sucker.
By the way, if you made it to 64k miles without previously replacing your clutch - then all I have to say is "WOW".
denverpete is offline   Reply With Quote
Old 07-31-2006, 08:28 AM   #3
Thanks for the reply denverpete. I was afraid to hear the clutch is the culpret. Is this an expensive job by the dealer or would you recommend a DIY? I saw some prices for the clutch kit online - somewhere around $350-$400. If it's a common wearout item, I probably should learn to replace it myself. I just finished the coolant expansion tank replacement 2 weeks ago; that was fun. Any suggestions? thanks again
Old 07-31-2006, 09:01 AM   #4
Unfortunately, it's a Porsche so of course it's not going to be cheap at the dealer.
Check out this forum link for a bit more information:
2002 Boxster S Clutch Replacement
Good luck and please post back with your dealer cost (if you go that route) or your opinion/write up if you do it yourself.
