Originally Posted by AllanAA
Thanks for the reply denverpete. I was afraid to hear the clutch is the culpret. Is this an expensive job by the dealer or would you recommend a DIY? I saw some prices for the clutch kit online - somewhere around $350-$400. If it's a common wearout item, I probably should learn to replace it myself. I just finished the coolant expansion tank replacement 2 weeks ago; that was fun. Any suggestions? thanks again
Unfortunately, it's a Porsche so of course it's not going to be cheap at the dealer.
Check out this forum link for a bit more information:
2002 Boxster S Clutch Replacement
Good luck and please post back with your dealer cost (if you go that route) or your opinion/write up if you do it yourself.
