Old 09-26-2017, 11:05 PM   #1
Finally found a center wind deflector
Finally found a center wind deflector for my 2001 Boxster S. Now just need two more pieces and the Boxster is complete.
RobertKing is offline   Reply With Quote
Old 09-27-2017, 04:21 AM   #2
I have one for sale.
Also have like new rear tail lights
Stock 17 inch rims and a complete top with frame with good fabric but needs a window
Fuzzuki is offline   Reply With Quote
Old 09-27-2017, 04:31 AM   #3
DrCactus's Avatar
I have one of those wind deflectors but it seems to rattle a little and been thinking about removing it... does it really make a difference?? I never driven the car without it so I am not sure what the difference will be...
DrCactus
Old 09-27-2017, 05:11 AM   #4
Your mounting tabs on the rollbar are more than likely broken. Pelican or ECS sells them for cheap. They're usually riveted to the roll bar
Woody
Old 09-27-2017, 06:10 AM   #5
steved0x's Avatar
Yeah, and the little clip that is on them has been revised at some point by Porsche, mine used to rattle around and new clips resolved it for me and were easy to install. Was only a few $.
Old 09-28-2017, 08:04 AM   #6
DrCactus's Avatar
Thanks... I'll need to replace those clips as one of them rattles like a MOFO. I almost put crazy glue on it to stop! haha
DrCactus
Old 09-28-2017, 08:46 PM   #7
1997 Tip, 2018 Macan
rexcramer's Avatar
Count me as a believer. My car didn't come with them. I nervously paid $460 for the set. IMHO it is night and day for the better.
Old 10-02-2017, 06:23 PM   #8
Just an update. Got the center deflector in today, sadly, one of the clips was indeed broken. Had to order a set so, getting really close to brand new cost at this point.
Old 10-03-2017, 12:35 AM   #9
you'll have to send a pic when its on. When I got my car the defector was in the boot, I tried to fit it then noticed one of the clips on the roll bar was broken (probably why it was in the boot)
I got one from a breaker for £5. drilled out the rivet and riveted in the new one, being very careful. Took about 5 mins.
Im not sure how well the deflectors work but they sure look good. More so when you can read the Porsche lettering through the rear window when the hood is up.
eeeeee...... its the simple things in life that bring the most joy lol
YellowS2000 is offline   Reply With Quote
Old 10-25-2017, 05:50 PM   #10
Old 10-25-2017, 07:01 PM   #11
I use mine in the late fall through the winter here in NW Florida. It really makes a difference on wind hitting the back of your neck. IMHO, you can enjoy your car at least 10 degrees cooler that without.
dghii is online now   Reply With Quote
