Old 09-22-2017, 05:52 AM   #1
Shifter cable replacement
Hi guys,
I am in the middle of replacing the shifter cables on my 2000 boxster S 6 speed. I have the old cables out but now looking at the new numeric racing cables there appears no way to get the new reverse cable through the tiny brake tunnel under the center console. I have not found anything on this online, any suggestions? Do I have to remove the hand brake assembly?
Thanks.
gpope is offline   Reply With Quote
Old 09-22-2017, 06:43 AM   #2
Originally Posted by gpope View Post
Hi guys,
Thanks.
Yes. Only 4 nuts and the back right is a two part bolt. Real easy
Woody
Old 09-22-2017, 07:30 AM   #3
Posts?
Are 2 of these nuts those taller post looking bolts that have threads inside them? Sorry I don't know the name of them. If those are them then I am assuming I just use a deep socket to get them out?
Thanks for the reply!
Geoff
Old 09-22-2017, 08:05 AM   #4
Schatten-Baum-Mechaniker
on my 2000 s, one cable was routed around instead of through.
Tommy
2000 Boxster S
1973 914
tommy986 is offline   Reply With Quote
