Old 07-28-2006, 09:20 AM   #1
Unhappy oil warning light
Having some problems with my 2000 Boxster and the mechanics do not know what is wrong.
Oil Warning Light was coming on once in awhile, but when you accelerated or raised the RPM's the light would go off. So figured it was just low on oil, added 1 Quart and then I checked the level and it looked full. But the light returned and now the Engine Warning Light is coming on once in awhile. Took it to mechanic and they heard a whining noise when we started the car up. They said serpentine belt had to be replaced. Took engine apart and belt was fine, and with belt off, it still makes whining noise. They are now talking about oil pressure and oil pressure canister, but they said they will have to tear engine apart to try to find out what is wrong.
Note: When they hooked the car up to the machine to read the CEL, it said it was the Oxygen Sensor.
Does anybody have some thoughts on this or what might be wrong?
2kBoxster is offline   Reply With Quote
Old 07-28-2006, 11:02 AM   #2
Brucelee's Avatar
My guess is simply a bad oil pump.
Second would be some issue between engine and semi dry sump.
Rich Belloff
Old 07-28-2006, 01:28 PM   #3
Send a message via MSN to CJ_Boxster
Same here, oil pump goes and you will hear whining in the engine...do you hear lifter klattering yet?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 07-28-2006, 01:44 PM   #4
deliriousga's Avatar
Oil pump or oil separator. When the separator goes, the oil filler tube collapses, cracks and starts to make whining sound that is similar to a slipping belt.
1966 Wife White/Brown Top
Old 07-29-2006, 09:23 AM   #5
Remove the oil pressure sender and install a gauge to measure the pressure at idle with the engine at operating temp and over the RPM range of the engine. It could be just that the pressure sender is going south.
wvicary is offline   Reply With Quote
