08-28-2017, 06:37 AM
#1
2001 Boxster S 6sp
How many miles on a tank typically?
Getting ready to take a trip from South of Tucson,AZ to Northern Illinois. I have a 2001 Boxster S. I know some of you have taken some lengthy trips and might be able to tell me how many miles I can expect to go conservatively between fill ups. Just trying to plan my fuel stops.
Any help appreciated.
2001 Porsche Boxster S
2022 Hyundai Santa Cruz
1983 Alfa Romeo Spider (PO)
1969 Morgan 4/4 1600 (PO)
08-28-2017, 06:52 AM
#2
01101
2002 S: Typically on trips I go 300 - 320 miles between fills.
Longest tank ever was 337 miles, average including every fill is 270 miles.
08-28-2017, 06:59 AM
#3
2000 base-i usually get closer to 350 per tank on highway trips.
Sent from my 986 frunk using Tapatalk
08-28-2017, 07:13 AM
#4
On the slippery slope
Kinda depends on how fast you drive and what the terrain is
I have at time averaged over 27 mpg, so a full tank would go over 400 miles
I would say you can go safely at least 350 miles on a full tank and have reserves
2004 996 Targa Tip
Instructor - San Diego region
08-28-2017, 07:44 AM
#5
1999 2.5
Highway driving about 330-343 miles. This last tank was alot of driving on highway and got 343 miles on a tank.
Normally average about 284-300 miles back and forth to work on a tank.
08-28-2017, 08:26 AM
#6
2001 S
I get 235 miles IF I am lucky...
DrCactus
08-28-2017, 09:20 AM
#7
Originally Posted by DrCactus
2001 S
I typically get 25 mpg on the highway, have also seen the high 20's. I drive speed limit +10 mph most of the time with higher speeds in bursts.
If I DE or AX it drops to 10 mpg or lower. :-)
What do you do to get only 235 miles or less?
1941 Dodge Luxury Liner Coupe
08-28-2017, 10:10 AM
#8
2001 S
Yup about same for me. Maybe 250.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
08-28-2017, 10:28 AM
#9
Multi-Boxer Driver
I've had several 400 mile tanks.
Usually it's around 320 miles, though - mostly a mix of city and highway.
-Chris
2004 Porsche Boxster 2.7 (gone  )
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
08-28-2017, 10:47 AM
#10
2001 Boxster S 6sp
Thanks for all the responses. I will let you know what I get.
08-28-2017, 10:50 AM
#11
On the Hwy I to see 400+ mile tanks but I usually start looking for gas once I drop under 100 miles to go. So really I am refilling about every 5 hours/300 miles hwy travel
Mixed driving I concur that you will seeing 325-350 miles depending on how hard you drive and how much stop and go
Seal Grey
08-28-2017, 11:22 AM
#12
On a highway trip you should be able to get 350 miles and still have a decent amount of gas to start looking for a place to fill up, maybe 400 miles if there are plenty of gas stations along the highway. That's been my experience on long distance trips with my 2003 S. On the other extreme, when I am at an HPDE I will use over 1/2 of a full tank over a day consisting of 4 sessions of 20-25 minutes each. But I'm fine with that, I see plenty of guys refilling their cars between sessions, they have to have gas cans on their trailers!
08-28-2017, 11:36 AM
#13
2001 S
2007 CS
Me too, usually get between 225 and 260 during combined city/highway in the congested LA/OC traffic (averaging 19 mpg)
08-28-2017, 01:26 PM
#14
My range is bladder dependent.
08-28-2017, 05:03 PM
#15
1997 Tip, 2018 Macan
In the last 12K miles, I have averaged 20.5 mpg. The farthest I've gone on a tank is +/-300 miles. I rarely wait until the light comes on to refill.
08-28-2017, 05:07 PM
#16
Ditto here. 12 miles on surface roads, 15 on interstate to work and I get around 18-19 mpg.
Guards Red Boxster S, born in Germany May 2004. LN spin on filter, litronics, roll bar mesh, wind deflector. Pioneer AVH-4200 hu, rear shelf box with speakers installed. 36k miles.
08-29-2017, 11:38 AM
#17
275 on a regular basis.
2 0 0 1 S
08-29-2017, 06:09 PM
#18
used the 02 s for 5 years on a sales route....always 280 miles per tank, staying in the throttle alot. mixed bag of traffic conditions. Come to think of it going to Sebring all highway around 300 mpg. Wait....am I really talking about gas mileage...who cares ,drive it like you stole it. You have plenty of money you own a Porsche!
08-29-2017, 09:17 PM
#19
I have an 01S.
I have taken three long distance trips, and I always plot out every gas stop ahead of time to program in my GPS. If you are cruising on relatively flat and straight I-roads, you can press 350-375 miles. Once I made 400 (on fumes).
Plan on around 300 as others have said. I am doing a 5,00+ mile road trip throughout CO, AZ and UT in September and target that as the refill mark.
I have never been lower than 275 with the hardest driving that I do, and while not on Jimmy Johnson level, neither am I "let's see how much mpg I can get".
DBear
08-30-2017, 07:56 AM
#20
Just did that trip in reverse northern IL to Phoenix in July got a consistent 25-26 mpg. 98 base at 80 mph average with AC on.
Safe travels,
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
