-   -   Calling on Master Mechanics… Again. (http://986forum.com/forums/boxster-general-discussions/68522-calling-master-mechanics%85-again.html)
Jager 08-27-2017 12:48 PM
I successfully replaced the chain tensioners on my 2001 Boxster this weekend but the deviation on bank 2 did not get under 6 degrees… What can cause this? Chain? Solenoid? Thanks
http://986forum.com/forums/uploads02...1503863206.jpg
http://986forum.com/forums/uploads02...1503863235.jpg
http://986forum.com/forums/uploads02...1503863265.jpg
http://986forum.com/forums/uploads02...1503863323.jpg
Gelbster 08-27-2017 09:06 PM
Remember "7 links apart" ? It is very easy when refitting the camshafts (particularly Bank 2) to have the chain slip 1 tooth. You need to use a paint Marker pen on both sprockets and both links. Even so, it is very difficult to check your work on Bank 2.
How did you confirm that Bank 2 Solenoid and Actuator are functioning correctly?
Did you dismantle the Actuator?
Replacing the Tensioner for Bank 2 is quite difficult -access. Did you soak it first?
Check some of the Threads by dporto in 996 Section for "hard reset".
If your Durametric reading is with a cold engine it may be misleading
This could take a while to diagnose. Ask me .........
Pdwight 08-27-2017 09:14 PM
Wow that looks foreboding
Did you do this while the engine was in your car ??
And one more question please, after replacing the tensioners / does the engine still rattle when first started cold...I have always been curious about this
78F350 08-27-2017 09:40 PM
Myself, not even being a YouTube certified mechanic, did similar work on an Audi V8. Rather than just changing the pads, I replace the entire tensioner on both sides. After putting it back together and turning the crank, the link count was off by 1/2 link on one side. Turned out I had the tensioners on the wrong side. They fit and looked identical other than the part number. Any chance you swapped the tensioners?
Jager 08-28-2017 05:57 PM
Gelbster,
Remember "7 links apart" ? It is very easy when refitting the camshafts (particularly Bank 2) to have the chain slip 1 tooth. You need to use a paint Marker pen on both sprockets and both links. - The chain had different color links to line-up with the marks on the cams, I'm positive chain position is not the issue here.
How did you confirm that Bank 2 Solenoid and Actuator are functioning correctly? - I did not confirm the actuators are functioning, that's why I am wondering if these readings are an indication of a failed actuator.
Did you dismantle the Actuator? - No
Replacing the Tensioner for Bank 2 is quite difficult -access. Did you soak it first? - I did not find it anymore difficult and no I did not soak them.
Check some of the Threads by dporto in 996 Section for "hard reset". - Thanks
If your Durametric reading is with a cold engine it may be misleading - The engine was warm.
Pdwight,
Did you do this while the engine was in your car ?? - Yes
And one more question please, after replacing the tensioners / does the engine still rattle when first started cold...I have always been curious about this -The engine starts better and runs better, probably because timing better overall, and it idles smoother. I never seem to have too much rattle during start-up before, maybe a couple seconds.
78F350,
Any chance you swapped the tensioners? - No, if you look closely at the last photo you can see one of the pads has a set of holes for oil feeds. Under that pad is an O-ring that fits between the pad and tensioner. They fit tight and did not come off after I installed them.
Jager 08-28-2017 07:56 PM
Update
I tried to activate the solenoids (engine running) with my Durametric and there was no response. I did a hard reset by disconnecting the "+" side cable from the battery and grounding it. Then when I restarted the engine and used the Durametric to activate the solenoids the motor almost stopped when I activated each side. So it seems both solenoids are working. Then I checked the cam deviation and there was no change.
Paul 09-05-2017 06:16 PM
I got similar results when changing out those pads.
https://uniim1.shutterfly.com/ng/ser...520284/enhance
Jager 09-05-2017 06:45 PM
Paul,
Did you go back and try to re-time Bank 1?
I have been contemplating pulling the oil pump on Bank 2 and trying to get the timing a little better. Six degrees at the crank is only three degrees at the cam.
Paul 09-05-2017 07:25 PM
Yes, it's on my going to do someday list.:)
Paul 09-05-2017 07:27 PM
I suspect the real issue is a worn chain and tensioner pad from the IMS to the head.
