Old 08-08-2017, 09:58 AM   #1
Abs
Hi my first post .Have a 986 boxster ,with abs light on bought the necessary code readers . Read codes front speed sensor fault . Cleared code checked no codes showing. Many times carried out procedures to clear abs light .but light has stayed on . Any help please Paul
Boxsterpdf is offline   Reply With Quote
Old 08-08-2017, 10:07 AM   #2
DrCactus's Avatar
The ABS wiring loom goes across the steering column and eventually it wears thin. This could be the reason... also have your battery tested as a dying battery can cause many strange issues.
DrCactus
Old 08-08-2017, 10:09 AM   #3
itskenallen's Avatar
Have u checked ur battery? Mine was failing and I was getting the abs light. Replaced battery, reset light and never came on since.
Sent from my Galaxy S8+ using Tapatalk
itskenallen is offline   Reply With Quote
Old 08-08-2017, 10:18 AM   #4
will try
Old 08-08-2017, 10:21 AM   #5
will have a look .Only happened after removing front wheel ???
Old 08-08-2017, 05:00 PM   #6
On the slippery slope
JayG's Avatar
What code reader are you using. A non Porsche specific one basic one won't give you all the codes
Measure the resistance of the wheel sensors. It could be one going bad
They should all be aropund the same, 1.6k ohm IIRC
I had a abs failure a little while ago and it was on sensor that was bad and it read significantly lower in resistance than the others
I ought a used on on ebay for ~ $35 and all is good now
2004 996 Targa Tip
Instructor - San Diego region
Old 10-27-2018, 08:35 AM   #7
Are the ABS Wheel Speed Sensors the same on all four wheels on a Boxster S ?
1stSP is offline   Reply With Quote
