Old 07-19-2006, 03:25 PM   #1
Rear spoiler not working at all
Hey guys. My friend bought a 1998 boxster yesterday & the spoiler does not extend at 75mph or using the manual switch in the fuse box. I checked the fuse for it andthe fuse was good. Is it possible that a sensor or a switch has gone bad? or even possibly the motor?
Thanks.
RevViNg HiGh is offline   Reply With Quote
Old 07-19-2006, 04:11 PM   #2
Brucelee's Avatar
My guess is the switch, then the motor.
Let us know.
Rich Belloff
Old 07-20-2006, 12:54 AM   #3
boggtown
Posts: n/a
I would maybe try and bypass the switch or check for current right at the motor, but if that doesnt work you could take out the motor and hook it up to see if it will work. Just another excuse to get an aero kit spoiler or aftermarket one.
Old 07-20-2006, 11:22 AM   #4
deliriousga's Avatar
Don't forget the relays. Swap the up relay with the down relay and see if it suddenly goes up but won't come back down. If so, the relay is bad. There's a relay chart on my website under "Where Is It?"
Good luck!
1966 Wife White/Brown Top
Old 07-20-2006, 04:22 PM   #5
Thanks. I will check it out.
Old 07-24-2006, 05:38 PM   #6
switched around the relays. Still not working. Where is the switch for the spoiler activation?
Old 07-24-2006, 08:03 PM   #7
boggtown
Posts: n/a
It is in the bottom left of the fuse panel. Take off the fuse panel, and you will see a finger hole, and a second hole, the second hole is where the switch goes through.
Old 07-25-2006, 08:55 AM   #8
Yea. That switch doenst work. All relays and fuses are good. Is this an item that will have to be replaced by a dealer?
Old 07-25-2006, 09:40 AM   #9
Remove the Fuse Panel screws and pull away to be sure that the electrical connector from the wiring harness is firmly attached to the switch...
Happy Motoring!... Jim'99
Old 07-25-2006, 01:54 PM   #10
That is my thought too
Happy Motoring!... Tim’05
http://i153.photobucket.com/albums/s..._kill/Siga.jpg
Dr. Kill is offline   Reply With Quote
