07-24-2017, 03:50 AM
Fault Code P1130
Hello folks, I keep getting this fault code P1130. I pulled out my sensor and cleaned it but after couple weeks the code keeps coming back. Can you tell me what is causing this to keep going off and how can I 'cure' this problem?
DrCactus
07-24-2017, 08:42 AM
What year is the car?
07-24-2017, 11:18 AM
2001 S model
DrCactus
07-24-2017, 01:05 PM
2001 S model
On that year, P1130 indicates:
1. Fuel pressure too high
2. Fuel injector is leaking
3. EVAP purge valve is stuck open
07-24-2017, 06:37 PM
JFP, is the EVAP purge valve the one that connects the throttle body to the charcoal canister?
If so, by blowing air into the tube at the throttle body end of the hose with the valve energized (12V), may clear the valve from carbon debris.
You kindly recommended this trick a couple of years ago and the CEL has not returned..
(hope don't jinx myself..LOL)
07-25-2017, 02:27 AM
Yes...............
07-26-2017, 06:33 AM
How do I go about checking for the problem?
DrCactus
07-27-2017, 03:49 AM
Does anyone know if driving the car still with the fault code P1130 will damage the car ? I cleaned the MAF sensor and that did not solve the issue...still not sure what the problem is.
DrCactus
07-27-2017, 08:01 AM
Did you try blowing out the Evap Purge Valve as suggested above?
07-27-2017, 09:52 AM
Indeed... tried that one
DrCactus
08-09-2017, 08:58 AM
Still having issues with fault code P1130 ... anyone else have some thoughts?
DrCactus
08-09-2017, 11:50 AM
Check your fuel pressure, scan the car for fuel trim values looking for an over rich condition.
08-25-2017, 07:29 AM
I'm having difficulty finding a picture that shows this connection (Evap Purge Valve). Does anyone have one?
2001 Boxster S, Guards Red
08-25-2017, 07:46 AM
How do I do this? If problem comes up what needs to be repaired ? Is this a serious issue that I should stop driving car or whats the result if I keep driving
DrCactus
08-25-2017, 07:47 AM
An old PIWISII will effectively test the system and report your issue in roughly 5min. Its FREE also (at the dealer). You can also ask your service center to quote for repairs (also free). That could give you a good idea to where to begin with this - if you DIY
Luck man
08-25-2017, 08:07 AM
Fuel trims require the use of a Porsche specific scan tool (PST II, PIWIS, Durametric system) and will tell you the exact air/fuel rations for each bank. The one that comes up out of spec tells you what kind of issue (overly rich/overly lean) you have and where it is.
08-25-2017, 08:59 AM
Luck man
You say that its FREE at the Porsche dealer?? How... man those guys do nothing for free it seems around here.
DrCactus
08-25-2017, 09:43 AM
At Porsche Canada, they will scan your car, diagnose, quote for the repairs and prep it for winter. Hang on, not finish; they will install your hard roof for you and give your Porsche car a fresh clean. All that for $200 (no joke man). Not free but pretty damn close!
Quote "all performed to the highest standards and according to your individual wishes"
About the same my indy charges for balancing my wheels (1hr labor)
Porsche Seasonal Checks - Porsche Canada
ps: yea we get our car scanned/diag free here. At the end of the day it always just make sense to let them carry out the work (they are expert at sales lolll) and they know that. Parts are same price and they are 3x faster than my 'economical' Indy here.
08-26-2017, 05:58 AM
Thanks mate! I'll definitely take advantage of this to get a 'baseline condition' for mine. I bet they'll have a nice waiting room and good coffee!
08-26-2017, 06:47 AM
Pleasure! haha yea that Espresso machine, space stuff my friend. I'll snap a pic nx time I'm in there (Porsche branded also, Proche maybe also, not sure...).
VVIP! They see you as the next 718 customer, you see! Expect free goodies also.
Porsche man, Porsche!
What I like most from these chaps is they are so down to earth. Some part one would recommend changing immediately, Porsche will tell you "pffff by the time the world ends and the car disintegrate, you'll still have a bit of life in that part - what's the point anyway"
In contrast, my 'economical' indy would say "Oh no no no, I can't let you leave my shop until you've changed this part. You'll kill yourself, the car will explode and debris from it will kill the pregnant women across the street in-the-face". I love you too much to let all of this this happen?"
DIY is the best I understand but I know nothing about Porsche cars. Good god have you seen their part# list?! LOL
