Old 06-22-2017, 05:37 PM   #1
Changed the ignition cylinder...
Man, was it fried....
Tried on Saturday to it under the dash, but I am simply too tall. I have bruises on my head and arm. Under the dash, I was able to get the inferior screw loose, but couldn't see or get to the top one. After 1 hour of trying to do it, I gave up...
Today, I decided to go through the left side of the dash, taking off the vent and headlight switch assembly.
Still a PITA, but much, much easier. Took about 40 minutes today.
Here's a pic of the ignition cylinder.
'98 Porsche Boxster
spinedoc is offline   Reply With Quote
Old 06-22-2017, 06:12 PM   #2
Yeah, I'm 6'1" and had to go through the vent as well. I hope to never have to do that again
Cbonilla is offline   Reply With Quote
Old 06-22-2017, 08:14 PM   #3
You did it the right way...Like anything else, its not a bad deal second time around.
Old 06-23-2017, 05:10 AM   #4
Xpit77's Avatar
Vent is the way to go unless you have one of those Mission Impossible harnesses suspended from the ceiling.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 06-23-2017, 06:03 AM   #5
One question
Since changing the cylinder. My key is a little stickier going into the tumbler. Doesn't insert as easily into the tumbler portion, not the cylinder itself.
Is that normal?
'98 Porsche Boxster
Old 06-23-2017, 07:09 AM   #6
The tumblers are in the lock cylinder.
Did you replace the lock cylinder or the ignition switch? Your post is confusing.
If you just replaced the ignition switch, it should not have affected the lock cylinder.
Old 06-23-2017, 07:21 AM   #7
I just replaced the ignition switch....nothing else. Just that now, when I go to put the key into the car, it doesn't just slide in, and I have to move it a little to get it to go in, and this is at the tip of the key, right where it slides into the tumbler...I wouldn't think that the ignition switch should affect that, but it's slightly different now.
'98 Porsche Boxster
