Old 06-19-2017, 11:40 AM   #1
Boxster Key Magnet
I lost the the little magnetic piece in my 06 boxster key.
Its the length of a thumb nail and the width of two stacked quarters.
I noticed that none of the key fobs sold online have this magnet.
I am unable to turn my car on without this magnet. Is the key totally worthless or what type of magnet could I buy to replace it? I tried using a simple kitchen magnet did not work.
Appreciate your help. Thank you.
alphabeta123 is offline   Reply With Quote
Old 06-19-2017, 12:13 PM   #2
still plays with cars...
BoxsterSteve's Avatar
Looks like a pill or jumbo grain of rice?
If that's the case, you're SOL. That would be the RFID device that communicates with the car when you turn the key to start it.
Save your shekels, you need to buy a new key from a dealership and have them program it too.
Six speed 2000 Boxster S
Old 06-19-2017, 12:23 PM   #3
+1.
The little pill device is programmed with a code which is sent via RF signal to the immobilizer to allow the car to start. If you lost the pill, then the car won't even turn over.
The only solution is to get a new pill and then you'll have to have the new pill programmed with the correct code so it communicates with your immobilizer.
Unfortunately, this can only be done by a shop that has the proper test equipment (the Durametric won't do this so you're stuck using a few of the more sophisticated indy's and/or a dealer).
Old 06-19-2017, 12:23 PM   #4
Magnet? Might you be referring to the battery?
It's size 2032 - same as many other car remote fobs. Found easily in countless pharmacies, grocers, big boxes, hardware stores and of course amazon, etc.
*not to scale - b/c I don't know what device you are viewing on
but it's about the size of 2 US quarters stacked
Otherwise there is a 'pill' in the fob's head but it's 1/2 the size of a tic-tac. Without it, you're sunk buying a replacement eBay fob b/c you need to xfer yours over. And if you haven't searched yet regarding replacement keys... you MUST have the barcode that comes w/ them (if a new 'pill' is being introduced and not transferring over an existing one to a new fob) b/c keys [the 'pill'] gets programmed to the car...
Good luck
"Cool Prius!"
- Nobody
Old 06-19-2017, 01:49 PM   #5
OP here:
If I bought a used car key online via amazon/ebay that was already programmed and had the deal reprogram it, would that be possible?
Do dealers reprogram used keys?
-Thank you
Old 06-19-2017, 01:55 PM   #6
It wouldn't be programmed to your car, so it wouldn't save you anything.
1941 Dodge Luxury Liner Coupe
Old 06-19-2017, 03:04 PM   #7
There Is No Substitute.
rick3000's Avatar
Originally Posted by alphabeta123 View Post
OP here:
-Thank you
Used keys are useless without the ID tag, you will need to buy a new key.
The key doesn't get programmed, the car gets programmed to accept that key. If the key doesn't have the ID number tag, there is no way to program it to work with the car.
Old 06-20-2017, 05:51 AM   #8
agrennan's Avatar
+1 on what Rick said.
One more thing, I would keep the blade in your current key. If you order a new transmitter with the pill and new tag ID attached, you can reuse the blade you have. It's the smallest expense of the pieces, but no reason to do it if you don't have to.
I recently made a duplicate key, as my car only came with one. Got the fob/pill/tag for about $125 online, blade for $5 and had it cut locally for $20, and got everything programmed at the dealership for $115.
agrennan is offline   Reply With Quote
